Balanced SEX
Karl5150 · 2664
on: July 27, 2015, 05:55:02 AM
Would the volume/balance set-up and wiring scheme used on the Stereomour II work on the SEX 2.1?
Presently it is wired with 2 mono volume pots which was great for fine tuning at home. Here in the office the volume needs to be quickly adjusted for phone calls, etc.
Online Paul Birkeland
Reply #1 on: July 30, 2015, 12:36:28 PM
It would work if you had the extra holes already, but it will cost you a few dB of gain.
You may find that a properly sized rubber band around the volume knobs will get the job done.
Reply #2 on: July 30, 2015, 03:25:08 PM
Thanks Paul, who knew a rubber band could have the equivalent of 4dB of gain. It's worth a try. The KISS theory strikes again.
