Resistance (ohms) failure
rogerthatmand · 7426
Reply #15 on: July 31, 2015, 08:40:48 AM
Here are some things I would work on.
Can you use your DVM to measure the resistance from terminal 3 to terminal 7?  How about terminal 3 to terminal 9?
Reply #16 on: July 31, 2015, 11:08:27 AM
Also, on the tube socket is the white wire at pin 2 touching pin 1? may be labeled A1,A2, not sure...John
Offline Rocketman248
Reply #17 on: July 31, 2015, 08:53:10 PM
What's the wattage on your soldering iron.  It looks as though your iron is getting just hot enough to melt the solder on the tip, but not hot enough to adequately heat the junction.
Nick DeBrita
Yokosuka, Japan
Offline Strikkflypilot
  • Shellac fiddler
Reply #18 on: August 01, 2015, 03:08:34 AM
And make sure You have standard issue electronics solder (60/40 tin/lead) with rosin core.
None of that silver crap, damn hard to work with.
I read on a product page it would flow better than standard solder.
Still waiting for that to happen:)
« Last Edit: August 01, 2015, 03:36:23 AM by Strikkflypilot »
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline rogerthatmand
Reply #19 on: August 04, 2015, 07:49:25 AM
Guys, the frustration is strong with me.
I double checked everything you mentioned. I did fix everything you suspected was wrong (the white wire at the headphone jack seems to touch other wires actually).
But again, I tried to power it on and again - smoke.
The smoke is coming out of the transformer only! nothing else. It seems like the transformer getting over heated.
Any suggestions now?  :(
Reply #20 on: August 04, 2015, 08:54:11 AM
Folks this is another of the situations that happens occasionally where a lot of people are showing really good intentions in offering suggestions, but I fear the OP may be getting overwhelmed by all the posts. I would respectfully suggest we let PB work with the OP to sort this one in a methodical fashion.
Roger, don't turn the amp on again until PB posts some guidance. At this point the transformer is probably just fine, but a short somewhere else in the circuit is forcing it to draw way too much current when you turn it on. Eventually that will fry the transformer, and we need to figure out where the short is before running it for any duration. Now that you have resoldered a lot of the connections your best bet might be rechecking all of the resistances and posting any deviations.
Reply #21 on: August 04, 2015, 11:09:54 PM
Thank you for the comment.
I'll check again everything. But can you please explain what do you mean by "PB"?
  • Shellac fiddler
Reply #22 on: August 04, 2015, 11:39:24 PM
PB is Caucasian Blackplate AKA Paul Birkeland.
The one to listen to here.
Good luck BTW!
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Reply #23 on: August 05, 2015, 03:15:22 AM
Oh, ok.. thank you very much.
By the way, about the ohms testing, the black (negative) lead should be placed at 12L all the time? and the red one at the target terminal?
I'm not 100% sure what should i do with the black lead of the meter and I didn't quit understand it from the manual.
Thanks again in advance.
  • Shellac fiddler
Reply #24 on: August 05, 2015, 04:49:03 AM
I know it can be hard to slow down when building this great kit.
The manual is however very clear on this. Page 37 under resistance check tells You to attach the black test lead to ground and preferably terminal 12. Use a clip lead or gator clip so You can concentrate on hitting the right terminals with the red probe.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Reply #25 on: August 05, 2015, 09:50:27 AM
Did any of your faulty measurements clear up with some reworking of the amplifier?  Failing resistance checks generally indicates that the amp will blow a fuse when you try to power it up, so there's no need to do that until we clear up the majority of these issues.
I can't quite see for sure in your photos, but it's possible that the 270 Ohm  resistor that crosses over the power transformer may not be connected to the correct terminals.  That in and of itself would be enough to blow fuses endlessly, and that resistor would get nice and toasty in the process.
Offline Deluk
Reply #26 on: August 05, 2015, 12:21:32 PM
The pictures of the jack plug certainly seem to show a small solder blob  joining the top two wires, the red and white. PB has circled it on one picture but it's more obvious on one of the other Imgur ones.
Reply #27 on: August 07, 2015, 12:32:17 AM
Thank you again for the comments! really appreciate it!
I'll go check soon everything you said.
But please - I'd like to know about the testing - How should I really check the ohms with the meter? I'm not sure about the manual explanation.
Should I touch the black negative lead to 12L? I don't really understand the meaning "To the ground of terminal 12". By "ground" it means the plate itself?
It seems that I don't do the checkings right..
And what do you mean by "installing backwards"? Does it matter the direction I put the wire in the terminal?
Looking forward for replies,
Thanks a lot!!
« Last Edit: August 07, 2015, 12:33:53 AM by rogerthatmand »
Reply #28 on: August 07, 2015, 12:41:32 AM
Try this sticky:
http://bottlehead.com/smf/index.php?topic=4812.0
I think if you go through this you will either verify your ground or find where you have problems.  It traces it as you should have it wired.
Where I say "Clip your meter lead" I want you to use an alligator clip jumper to connect the black lead and the first ground point.  If you don't have one you need some.  Go to Radio Shack and buy some.  They are cheap and very handy.
Reply #29 on: August 07, 2015, 03:25:47 AM
Thank you, but I forgot the most important question I had  ;D
How do I check for shorted circuit? I truly believe there's a problem somewhere with shorted circuit at the transformer area.
I don't know what I should do to check it right.
