Hi guys
I finished my crack a couple of weeks ago however as I was getting weird interference through my PC audio card I was waiting for a DAC so that I can use the optical out of my PC to get rid of the interference.
Anyway, as I finally had a chance to listen to the Crack without any interference it sounds really great, however I have a few questions. First, if I move or hit the table on which the Crack is on, there is a loud pop. The harder I hit the table, the louder the pop is, and I was wondering whether this is normal or if there is something I have done wrong in the soldering? So if I don't move anything it's fine there is no popping sound, however if I put my glass of water for example on the table and this would cause a pop. Sometimes even when I am typing on my keyboard would make the Crack pop. Is this a problem with my soldering or? I was planning to reheat some of the solder points however I wanted to ask whether you can help me pinpoint the issue so I can save me some time.
It might be something to do with the headphone input since if I rotate the headphone jack while its inserted in the input, it makes similar popping/interference sounds. Maybe some of the wires on it aren't properly soldered or is this normal? If I hold the cable and the jack in place with one hand and don't move, everything is fine, but otherwise if the cable moves in any way, there is this "static"-y type of sound and a bit of popping.
Also there is a small background low pitched hum, but this might be due to the electricity especially in summer when every apartment in the surrounding area is running their A/C and the power grid is under a lot of strain. The hum is constant and doesn't change with lowering or increasing the volume, but it doesn't bother me since you cant even hear it, even when playing acoustic instrumental songs. But just trying my luck maybe there is an easy fix, so while I am here, I might fix this as well.
So before I go ahead and use it regularly I wanted to know if there is any way to fix these issues, especially the one with the headphone input since the other one could be theoretically solved by just putting the Crack on another table next to my PC table.
