Crack Ticking Noise/ Microphonics [resolved]
mrying · 3079
Offline mrying
on: August 06, 2015, 04:49:19 PM
Hi everyone!!  :)
I just finished building my crack amp. When I plug in my headphones into the crack there is a ticking noise and a bit of microphonics on the right channel of the headphones. It is still there when I turn the volume all the way down, I tried to unplug the Rca interconnects and when no source is connected.
Not sure what is causing this?
Thanks a lot!!
« Last Edit: August 12, 2015, 07:55:28 AM by Caucasian Blackplate »
Offline Strikkflypilot
  • Shellac fiddler
Reply #1 on: August 06, 2015, 08:08:17 PM
Did voltage and resistance tests check out?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #2 on: August 06, 2015, 11:43:35 PM
The proper way to assess noise with no input is to short the inputs.  Either use a shorting plug as Doc describes here:
http://bottlehead.com/smf/index.php?topic=586.0
. . . or use jumpers on each channel.  Those would go from the center conductor to the ground tab.  This eliminates all outside influences.
Offline mrying
Reply #3 on: August 07, 2015, 03:28:33 AM
yes the Voltage and Resistance test has been done. Everything seems fine. Weird because after a good hour or so the ticking and micro phonics were gone. I am guessing the tubes warm up and the sound went away. The background was pitch black after the hour. I will test it out again tonight and see if the tubes have to warm up first?
Thanks guys for the replies!  :) :)
Reply #4 on: August 07, 2015, 07:35:40 AM
This is often your cell phone interfering.
Offline adydula
Reply #5 on: August 09, 2015, 01:59:57 AM
I had my crack near my wireless router and heard lots of clicking and strange noises.....moved it a few feet away and the clicking goes away....lots of external things can induce nosie
into the crack.....
Alex
Offline mrying
Reply #6 on: August 11, 2015, 09:34:19 AM
Thanks guys, I do think it is the cellphone and wifi signal. My router is literally right beside the amp!!
Thanks for the input!!
Ying :) :)
