Bottlehead Kits
Legacy Kit Products
Quickie
replacement tubes for Quickie
sameerverma
3093
sameerverma
Newbie
August 18, 2015, 08:10:50 PM
I have a newly built Quickie 1.1
While the tubes that came in the box (Tungsram) are fine, what kind of tubes should I look for to replace these? Only 3S4?
Sameer
mcandmar
Hero Member
Not all engineers are civil
Re: replacement tubes for Quickie
Reply #1 on:
August 19, 2015, 03:36:54 AM
Or DL92 which is the European equivalent, and the MIL spec tubes are labelled VT-174 and CV820.
With a simple change of the heater circuit wiring you can also use 1S4/DL91 tubes. Identical tubes other then the heater voltage is 1.4volts vs 2.8volts.
Bottlehead Kits
Legacy Kit Products
Quickie
