only left channel work
jazzfan78 · 2120
Offline jazzfan78
on: August 19, 2015, 08:12:35 AM
hello i have problem with my crack.
i plug my hd800 and i hear only in left side, right channel no sound.
i been in friend house to check the hd800 with other amp to see if they are working fine. hd800 work with both sides.
i plugged other cheap headphone again only left side work.
i replaced big tube in crack from stock tube to SYLVANIA TUBE 6080WA but still no sound from right side.
here is my voltages check:
Terminal           Voltage                My Result
1                        75-90                    147
2                          170                     199
3                           0                         0
4                          170                     197
5                         75-90                    99
6                            0                        0
7                           100                    164
8                            0                        0
9                           100                     133
10                           0                        0
11                           0                        0
12                           0                        0
13                          170                     198
14                           0                         0
15                          185                      205
20                            0                         0
21                           206                      212
should i replace the small tube as well?
or maybe i should buy a new RCA plugs or the problem is maybe the washers or something?
Offline jazzfan78
Reply #1 on: August 20, 2015, 06:10:04 AM
Reply #2 on: August 20, 2015, 07:11:56 AM
You have a bad solder joint somewhere in the signal path. Check your resistances again, you may find a discrepancy. It is also usually more expedient to simply resolder everything than try to figure out where the fault is.
Online Paul Birkeland
Reply #3 on: August 23, 2015, 11:08:26 AM
Do both halves of your 12AU7 glow?
Do both LED's on the 9 pin socket glow?
Please refrain from plugging in your headphones till your voltage at terminal 1 is resolved.
