Bottlehead Kits
Legacy Kit Products
Reduction
Need advice on Lost Channel On Prototype Reduction Unit with Integration
JDeiner
4558
JDeiner
Newbie
August 20, 2015, 11:34:07 AM
I have built a number of Bottlehead Kits and love them. I needed a phono preamp fast and took the easy route by purchasing the prototype Reduction Unit from Bottlehead. I have used it sparingly over the last year or so (it sounds great however!!!). Recently I lost a channel. I switched tubes and phono inputs but the problem remains in the left channel. I have the manual but the prototype is wired differently and I don't want to dive right into it.
Any advice on trouble shooting the unit? Some logic or starting points would be greatly appreciated.
Jim
Grainger49
Hero Member
Re: Need advice on Lost Channel On Prototype Reduction Unit with Integration
Reply #1 on:
August 20, 2015, 11:59:33 AM
I would still take the resistance readings. Post any out of spec by more than 15%. The same for voltages.
Bottlehead will sort out the differences. But having that information here to begin with will give them a foot up.
JDeiner
Newbie
Reply #2 on:
August 21, 2015, 02:19:31 AM
I will do that. One thing I should have mentioned is that the channel went from weak to distorted to nothing. I was thinking it may be a bad cap, but they are new.
Doc B.
Administrator
Hero Member
Reply #3 on:
August 21, 2015, 05:48:32 AM
Check the heater voltages at each socket and make sure the tubes all glow.
JDeiner
Newbie
Reply #4 on:
August 21, 2015, 10:11:38 AM
One is glowing noticeably brighter than the other. Will check voltages.
JDeiner
Newbie
Reply #5 on:
August 22, 2015, 05:00:45 AM
And now both channels work after switching the tubes back and forth a couple time while swearing. I am going to leave well enough alone. Thanks for the help.
Bottlehead Kits
Legacy Kit Products
Reduction
