Target Ripple for Line Level Output stage
galyons · 3380
Offline galyons
  • Geary Lyons
on: September 11, 2015, 08:25:18 AM
I am using PSUD2 to design a tube output stage for a NOS DAC.  What is a good target for mV/uV of ripple on the B+?  I am amazed at the changes in ripple I see on PSUD2 just moving around C, LC & RC orders.  I usually target getting ripple to the uV range, but that is simply a "less is better" defaut!  I need some input to bring reality to the paralysis by analysis;)
Cheers,
Geary
Reply #1 on: September 11, 2015, 08:52:06 AM
You can't really just declare an arbitrary X mV of ripple. You have to look at the ripple as a percentage of the B+ and consider how that affects the circuit's S/N ratio. Start with what resolution your DAC chip is. 24bit? The best S/N you can get from 24 bit DACs these days is about -124dB. For SACD it's about -120dB. If it's a 16 bit DAC maximum theoretical S/N is about -96dB. So take one of those as your starting point and see how close you can get. It will be nearly impossible to hit those super low numbers with a tube stage unless you use a lot of feedback. So just figure to design the power supply for the lowest ripple you can muster. Typically that means some serious voltage regulation. If you get it low enough then you can just tear your hair out trying to get the 1/f noise out of the tubes because it will dominate - assuming you have the grounding perfect, excellent shielding, etc., etc.
Offline galyons
  • Geary Lyons
Reply #2 on: September 11, 2015, 12:57:21 PM
Oh yes I can!! It is not doing me a damn bit of good, but I can!!
Thanks Doc this is most helpful!
The DAC is 18bit, (AD1865).  Plate voltage on the output tube is 200V.  So if I understand you correctly, (no given there!), if I get down to about 1-3mV ripple, the noise would be down about -96 to -106dB.  And that would be in the range of the S/N ratio for the 18bit DAC, 110dB.
According to PSUD2 I can get down to about 2mv with a C-LC-RC-LC.  The first C is just a trimmer cap to get the voltage range.  The RC helps bring  the voltage down and provides some filtering.
If I get this to work, then Phase 2 will  be try some tube regulation.
Cheers,
Geary
Reply #3 on: September 11, 2015, 01:09:42 PM
I apologize, I misspoke a bit. What you want to look at for S/N is the amplitude of the ripple (and other noise) vs. the maximum output signal swing. For example if your tube has a mu of 20 and your DAC chip can put out .1volts so your max signal after amplification would be 2V, you need to get that S/N at -110dB relative to 2V, not 200V. This is obviously quite a bit more daunting task, and why I suggest you will probably have difficulty getting all the noise down as low as the theoretical S/N of a typical DAC chip.
Offline galyons
  • Geary Lyons
Reply #4 on: September 11, 2015, 01:27:37 PM
Crap! I was all excited!  Yep that is several magnitudes more difficult.  Back to PSUD2!
Thanks Doc!
Cheers,
Geary
Reply #5 on: September 11, 2015, 01:28:23 PM
Loading will also make some differences here, as a C4S will provide much more power supply isolation than something like a 22K resistor.
Additionally, if you setup a shunt regulator, you can further diminish the ripple you have to deal with.
(I'd leave it at 2mV and address any issues after construction)
