Mainline input selector
JamieMcC · 5793
Offline JamieMcC
on: September 11, 2015, 11:14:22 AM
I have been trying to do some AB testing between sources using the Mainlines input selector and while one channel switches over reasonably ok the other channel makes a annoying pop during the switch. So firstly should it be ok to switch between sources with the selector like this and secondly is there some kind of modification or different switch perhaps that would allow for a smother transition whilst switching from one live input to another on the fly so to speak?
Reply #1 on: September 11, 2015, 12:20:58 PM
This switch shouldn't exhibit any significant noise.  Did it melt at all when you soldered to it?  Do both your sources have 3 wire power cords?
On the Mainline I have next to me, there's just a slight sizzle when I switch inputs.
Offline JamieMcC
Reply #2 on: September 11, 2015, 12:44:33 PM
Hi Paul ok one source only has a two wire power chord.
Reply #3 on: September 11, 2015, 01:49:37 PM
You could try grounding the chassis of that component to earth or to the plate of the Mainline (or converting to 2-wire cord to a 3-wire cord).
Offline JamieMcC
Reply #4 on: September 11, 2015, 09:13:26 PM
Thanks Paul I will give that a go.
Cheers
Jamie
Offline Strikkflypilot
  • Shellac fiddler
Reply #5 on: September 11, 2015, 10:36:02 PM
I can report the same as Jamie here, rather loud pop on the left channel when flipping from input 2 to input 1, not so much the other way around.
The chassis of the switch seems to me to grounded to the plate already when it is screwed tight.
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
  • Shellac fiddler
Reply #6 on: October 06, 2015, 09:10:17 AM
I just noticed something else.
With input channel 1 selected, though nothing connected, I can, very quietly, hear the source playing on input channel 2.
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Offline NightFlight
Reply #7 on: October 13, 2015, 04:03:39 PM
That's crosstalk.
Reply #8 on: October 13, 2015, 06:25:26 PM
Actually that's not cross talk. Cross talk is left bleeding into right and vice versa. This is simply one source selection coming thru the ground to another source selection. It's very simple to fix. Turn off the source you are not listening to.
  • Shellac fiddler
Reply #9 on: October 13, 2015, 06:47:25 PM
Thanks Doc.
I was thinking to try some shielded twisted pairs.
Your solution is a bit easier and lot less costly:)
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
Reply #10 on: October 14, 2015, 08:40:34 AM
That's what's in there now.
  • Shellac fiddler
Reply #11 on: October 14, 2015, 10:04:55 AM
Of course, You're right, a shielded Cat 5 with twisted pairs..
I was thinking of one shield per pair, but am happy I don't have to now:)
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
