Records
aragorn723 · 2025
Offline aragorn723
on: September 11, 2015, 05:12:26 PM
Hi,
I was at the local record store the other day and found What's New by Linda Ronstadt.  It sounded good, but it had a noticeable warp when playing.  Is that ok?
Dave
Offline Bonzo
  • My name is Marco, best known as Bonzo
Reply #1 on: September 12, 2015, 01:43:56 AM
Warped records are quite common. Try using a clamp when playing, or search for some DIY recipes to make them flatter.
Ciao!
Bisogna avere orecchio!
Offline Chris
Reply #2 on: September 12, 2015, 08:44:21 AM
If it is bad enough (interferes with your listening enjoyment) and you want to pitch it, try Greg Weavers method.. Place the CLEANED record between 2 TEMPERED pieces of glass and place it in your preheated (middle rack) oven at 150 degrees for 12 minutes 'ish'.. Take out and let cool, then remove album.. If you dont succeed, try it again...  IF the warp is bad enough to not want the record, why not give it a shot...
Offline aragorn723
Reply #3 on: September 13, 2015, 07:11:10 AM
Hi,
So it sounds like a slight warp isn't a big deal as long as the record plays?
Dave
Offline Bonzo
Reply #4 on: September 13, 2015, 09:51:05 AM
Yes.
I have lots of warped records, no problems for me!  ;)
