2a3 tubes
howardnair · 7742
Offline howardnair
on: June 28, 2010, 01:35:05 PM
having ordered a stereomour--i am now curious about all the different 2a3 tubes--opinions on the JJ 2a3 40 watt---the shuguang2a3c --the shuguang 2a3z-sino--sovtek and any others--i noticed the jj2a3 40 watt has just that- 40 watts of dissipation--how much of a benefit is that compared to the others--thanks howie
Reply #1 on: June 28, 2010, 03:53:09 PM
When my stock Sovtek tubes wore out I ordered a pair of Shuguang 2A3Cs.  I had nothing to fairly compare them to but loved the sound immediately.  I have since bought a pair of RCA Blackplates and they are better.  Not by a great margin but meaningful.  They are not used often.
Offline Dyna Saur
  • Yippie-Ki-Yay....
Reply #2 on: June 28, 2010, 04:21:46 PM
The J/J 2A3-40 is essentially a 300B, with a 2.5V, 2.5A filament.   2A3 is normally rated at 15Watts PD.
In a Paramour (or  Stereomour), it would behave as a 2A3 would, dissipating 15W or less.
Power output would be the same as a "normal" 2A3.
HTH
/ed B in NC
« Last Edit: June 28, 2010, 04:23:32 PM by Dyna Saur »
ed brown
Offline howardnair
Reply #3 on: June 29, 2010, 01:15:52 AM
thanks--i will order the shuguang 2a3c's  -howie
Offline richardl
Reply #4 on: June 30, 2010, 12:34:28 PM
They need to be run around 60mils in current to be happy.  They are very quiet and sound quite good.  Cheap too. I believe that they are in essence a Sovtek 300b that runs at 2.5v.  Richard
Online Paul Joppa
Reply #5 on: June 30, 2010, 03:50:50 PM
So, you would not expect them to sound their best in a Paramour or Stereomour, which run 50mA?  We'll have to try that some day!  :^)
