Help to troubleshoot my Crack (RESOLVED :)
Ju29 · 8394
Offline Strikkflypilot
  • Shellac fiddler
Reply #15 on: October 27, 2015, 07:46:33 PM
Might be grasping at straws here. Have You take the 6080 out and cleaned the pins and checked that the socket is tight for all pins?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline Ju29
Reply #16 on: October 28, 2015, 05:17:17 AM
Hi, I checked and the socket tight for all pins and for both tubes.
I didn't mention because I hadn't really paid attention but when I switch on the crack only one hear (the right one) works for about 10 to 15 seconds. Then there's a pop in the left hear and the crack works fine for 3 to 6 minutes. And after that no sound on the left hear anymore.
Resoldered again a few this morning but same pb. Can the issue be related to the headphone jack or there's absolutely no link between this part and my pb ?
Offline Dnorris
Reply #17 on: October 28, 2015, 05:46:48 AM
Isn't it also possible it could be a nicked/broken wire rather than a soldering problem? Might be time to try a careful chopstick test to see if wire movement causes any static/pops/noise.
Dale Norris
Offline Ju29
Reply #18 on: October 28, 2015, 06:12:10 AM
Thanks for your reply Dale. I asked myself this when I almost desoldered everything the first time. I would remplace a couple of wires just be 100% sure but I don't have that much left. Do you know if there's a way to check their integrity them without removing/desoldering them ?
I also wonder if one of the tube sockets could be the pb (just a suggestion... I don't know if that's possible // ??)
....Is HAS to be somewhere..
I will resolder few others later, again... For now I do have to go on my guitar build. Much easier  :-\
Offline richmi
Reply #19 on: October 28, 2015, 06:57:33 AM
Again, This looks like intermittent contact. Perhaps a solder joint that you are missing each time you go around them or perhaps a broken wire as suggested by others. Taking apart your build and putting it back together is also an occasion to break parts. Some joints with multiple wires or parts require more heat and solder to be adequate. You do not necessarily have to undo the connexions to make them sound, only reheat them and apply a bit more solder. Make sure you have good mechanical connexion (good loop around the terminal) before soldering.
I would suggest that you ask a friend to look at your build and check it against the manual. A fresh pair of eyes could see something that you keep missing.
As PB said, measure the 3K resistor between 3U and 9L to make sure it is good and inspect around there to see that everything is okay.
I am not an electrician, but some of your voltages that are on the high limit side might be related to your mains voltage. I had similar readings in some of my kits, and found out that the voltage coming into my house was around 125 volts. The manual says that the voltages were made with an AC mains voltage of 119VAC.
Where in Canada are you located? I am in Montreal. I could look at your amp if you are nearby. I have spare tubes and parts for the Crack.
Richard
Richard Milette
Seduction C4S
Extended Foreplay III (converted to 6SN7 Nov. 2011)
Paramount 300Bs
Crack (6SN7) + Speedball + HD650
Offline kgoss
Reply #20 on: October 28, 2015, 07:09:25 AM
Just a troubleshooting suggestion, but the fact that you are able to repeatedly create these symptoms makes a big difference.  Next time you get a chance to work on your amp run it upside down in the base, or on books, etc.  The key is to have easy access to the bottom so you can perform a complete voltage check while the problem is occurring. Post any voltages here that are out of spec and someone a lot more knowledgable than me will help you sort it out.  If the voltages are all good when the sound stops then I'd look long and hard at the signal path wiring.  Paul B can help you trace that by taking measurements with your meter while playing a test tone.
And if you can't reproduce the problem with the amp upside down you'll just have to build a clear cover and run it that way from now on!  Just kidding😀.   If you can't reproduce the problem with it upside down that provides clues too.  That would send me looking for a mechanical issue caused by gravity when the amp is in the base.
Don't get discouraged. PB and the rest of the BH team are great at solving these tough issues and won't give up until your amp is fixed.
Ken Goss
Offline Ju29
Reply #21 on: October 28, 2015, 07:47:46 AM
Thanks for your replies. Offer very appreciated Richard, thanks. I stay in Hull close to Ottawa. No trip scheduled to Mtl soon but if my plan changes (and if have still have the pb at this time) I'll let you know... The 3K resistors measurements are ok (and the others resistors as well). Well noted also about the two others pairs of eyes around me.. :)
Ken I did that already. I've posted my voltage measurements when the pb occur : every measurements are perfects when both sides work in my headphone. When the left side stops after a couple of minutes, B6 and T9 are down to 0 and almost all others voltage measurements increase slightly (see my first message for the exacts measures). I've also made once a resistance check when the issue occur I got 0.08 at T6 and T10 instead of 2.9K but I didn't repeated the measurement. So that is based on a one time measurement... Also the RCA jack (white) seemed to be at 0 or at least I wasn't able to measure anything (the red one was at 98). And the pb occur when the crack is on both sides (so no need to get a clear clover... :)
About the soldering I made sure for each of them that there were a good/large contact between the wire and the terminals. When I destructed the crack I removed the solder/used sandpaper and used a sharp knife to scratch a little bit the terminals to make sure there would be a good contact. Then I resoldered as I said before. Since I do as Grainger kindly advised me in his message, last paragraph.
About the BH team, yes I hope so.. Without any news from them since a couple of days I guess I have to continue to use my solder and check and recheck my solders..
« Last Edit: October 28, 2015, 08:00:08 AM by ju29 »
Reply #22 on: October 28, 2015, 08:17:58 AM
Once the problem occurs, can you confirm that your voltages on terminals 1-5 are still correct? (You are right, they will pop up a bit)
Once you have the problem and are able to measure your voltages, try measuring the voltages on B1-B3.
In particular, I'd like to see if B1 and terminal 1 have different voltages when the problem occurs.
Offline Ju29
Reply #23 on: October 28, 2015, 08:35:09 AM
Hi Paul, thanks for your reply.
From my notes :
Terminal 1 : 83 before the pb // then 89 when the pb occur
Terminal 2 : 173 before the pb // then 198 when the pb occur
Terminal 3 : 0 before the pb // then 0 when the pb occur
Terminal 4 : 173 before the pb // then 197 when the pb occur
Terminal 5 : 80 before the pb // then 88 when the pb occur
B1 : 83 before the pb // then 89 when the pb occur
B2 : 172 before the pb // then 194 when the pb occur
B3 : not quite sure one this one // then 121 when the pb occur
I have to leave in a couple of minutes. I will do an other measurements in a few hours when I'll be back. I measured many time and every time the result was the same result. But again, I'll do an other test just to be 100% sure.
Thanks !
Reply #24 on: October 28, 2015, 10:31:48 AM
Oops, I got mixed up (thought 7 was the issue).
Try the same test on B4, B5, B6 and terminals 5 and 9.
Offline Ju29
Reply #25 on: October 28, 2015, 12:01:37 PM
Since the left hear doesn't work for the first 10 to 15 seconds I thought that would be a good idea to get the measurement as well for this short time. So I plugged/unplugged a couple of time, waiting a minute between two measures. 10 seconds is a short time and and wanted to get accurate measures.
So here are my fresh voltage measurements I've just made :
B4 : the 10 first seconds 89 // then 79 for 3 to 6 minutes // then back to 89
B5 : the 10 first seconds 238 (!!!)[/b] // then 170 for 3 to 6  minutes // then 194
B6 : the 10 first seconds 0 // then 103 for 3 to 6  minutes // then back to 0
T5 : the 10 first seconds 230 (!!!)[/b] // then 79 for 3 to 6 minutes // then 89
T9 : the 10 first seconds 0 // then 103 for 3 to 6 minutes // then back to 0
Others measures (just in case) :
B1 : the 10 first seconds (?) // then 83 for 3 to 6 minutes // then 89
B2 : the 10 first  seconds (?) // then 170 for 3 to 6 minutes // then 194
B3 : the 10 first seconds (?) // then 107 for 3 to 6 minutes // then 120
B7 : the 10 first seconds (?) // then 0 for 3 to 6 minutes // then 0
B8 : the 10 first seconds (?) // then 0 for 3 to 6 minutes // then 0
T1 : the 10 first seconds (?) // then 83 for 3 to 6 minutes // then 89/b]
T2 : the 10 first seconds (?) // then 170 for 3 to 6 minutes // then 194
T3 : the 10 first seconds (?) // then 0 for 3 to 6 minutes // then 0
T4 : the 10 first seconds (?) // then 170 for 3 to 6 minutes // then 194
T6 : the 10 first seconds (?) // then 79 for 3 to 6 minutes // then 89
T7 : the 10 first seconds (?) // then 107 for 3 to 6 minutes // then 120
T8 : the 10 first seconds (?) // then 0 for 3 to 6 minutes // then 0
T10 : the 10 first seconds (?) // then 0 for 3 to 6 minutes // then 0
I wait for you feed back. Thanks for your help !
PS: I may be completely wrong but I have the impression to hear something (in the bulb I think) when the measures changes.
PS2: It will work !
« Last Edit: October 28, 2015, 12:06:05 PM by ju29 »
Reply #26 on: October 28, 2015, 12:10:57 PM
PS2: It will work !
Yeah, we'll get you there.
Ok, I have one odd suggestion for you that will about wrap up the diagnosis.  Remove the wire at B3 and remove the wire at B6 (just at the octal socket end, you can leave each free end poking up and hanging in the air).
Wire a temporary jumper from terminal 7 to B6 and a temporary jumper from terminal 9 to B3.
Now remeasure and see if the 0V reading has moved terminals or remains where it was.
Offline Ju29
Reply #27 on: October 28, 2015, 01:24:29 PM
Argh, I was so proud of this solders. B3 and B6 were my favorites !!
Just kidding.. :)
Here are the measures :
B4 : the 10 first seconds 0 // then 0 for 8 minutes (didn't wait any further).
B5 : the 10 first seconds 238 // then 194 for 8 minutes (didn't wait any further).
B6 : 0 // then grow slowly during the 10 seconds to stop at 119. Didn't change after for 8 minutes (didn't wait any further).
T5 : the 10 first seconds 230 // then 89 for 8 minutes (didn't wait any further).
T9 : the 10 first seconds 0 // then still 0 for 8 minutes (didn't wait any further).
Fingers crossed..
« Last Edit: October 28, 2015, 01:34:51 PM by ju29 »
Reply #28 on: October 28, 2015, 01:32:49 PM
If B6 never fell back to 0V, then we can conclude that the 6080 is working properly, the socket is working properly, the solder joint at B5 is good, the solder joint at B4 is good (despite your 0V reading at B4, which isn't possible based on all other information), and that the path from ground, through the 3K resistor, and to the terminal strip is working on the headphone jack side of the amp, but not the volume pot side of the amp.  This also confirms that the 12AU7 is doing what it needs to do to bias both halves of the 6080 properly.
This is absolutely a flaky connection, likely at terminal 3 or terminal 9.
It might help to triple check the resistance between terminal 3 and terminal 9, to make sure that terminals 9 and 10 don't have any debris between them that's conducting, etc.
Offline Ju29
Reply #29 on: October 28, 2015, 01:34:34 PM
Hi I've posted the wrong measures...
(I removed B4 instead of B3 so the former measures are not what you asked me...)
I post the right one in few minutes....
« Last Edit: October 28, 2015, 01:50:13 PM by ju29 »
