Help to troubleshoot my Crack (RESOLVED :)
Ju29 · 8341
Offline Ju29
on: October 24, 2015, 06:51:58 AM
Hello,
I built my Crack yesterday (speedball not installed yet). Everything went as it supposed to until the voltage checking (terminal 13 more precisely). My hand shaked and I did a short-circuit touching the 270 ohm 5w resistor (the one between the terminal 21U and the 15U) and the terminal 13 during the checking. There was a sharp little "bang" like a cracker.
The tubes seems to be ok, they still glow..// (?), the fuse is also ok.
As the result I tried the Crack with cheap headphones in cas it could damage my 650. It worked fine until the left hear stopped working in the headphone after a couple of minutes. Then I switched off the Crack for few minutes and turned it on again. It worked ok and then again, the left hear stop after about three minutes.
The voltage changed between before the short-circuit and after (terminals 1 to 12). The ones at zero remained at zero.
HERE ARE MY VOLTAGE MEASURES BEFORE the short circuit () and AFTER :
(The resistance check was spot on. I haven't checked them again since the short-circuit)
Terminal 1 : (before : 83) // after : 89 (should be 75-90)
Terminal 2 and 4 : (173) // 198 (should be 170)
Terminal 5 : (80) // 88 (I have to double check, I wrote it changed to 88 to 0 then 88 and so on) (should be 75-90)
Terminal 7 : (109) // 121 (should be 100)
Terminal 9 : (109) // 0 (!!!) (should be 100)
Terminal 13 : (?) // 198 (should be 170)
Terminal 15 : (?) // 210 (should be 185)
Terminal 21 : (?) // 223 (should be 206)
Terminals A1 and A6 : (?) // 89 (should be 90)
Terminals B1 : (?) 89 (should be 90)
Terminal B2 : (?) // 198 (should be 170)
Terminal B3 : (?) // 121 (should be 100)
Terminal B5 : (?) // 198 (should be 170)
Terminal B6 : (?) // 0 (!!!) (Should be 100)
Terminals 3, 6, 8, 10, 11, 12, 14, 20, A2, A4, A5, A7, A9, B7, B8 : (0) // 0
Clearly there's a problem with the measures of the terminals B6 and 9. They are at 0 instead of 100 (again, the measure of the terminal 9 was ok with 109 before the short-circuit...).
Would someone have an idea of what should I check and should I do to troubleshoot my Crack now ??
My guess is that one of the capacitors is dead or damaged. But that's only my guess (I don't know anything in electronics...). Also the "little" tube has to top black on the inside (seems like black powder). Is that normal ? I didn't pay attention before and don't remember if it looks normal like that...  (cf. picture below) It still glow but much less than the "bigger" tube.
THANKS A LOT FOR YOUR HELP ! I was SO close to complete the build without any problem, arghhh.... :)
« Last Edit: November 04, 2015, 07:34:03 PM by Ju29 »
Reply #1 on: October 24, 2015, 07:27:17 AM
Where you had your accident would have no impact on terminals 6-10.
You most likely have a bad solder joint, backwards 100uF capacitor, or wiring error around the octal socket.
Offline Ju29
Reply #2 on: October 24, 2015, 07:40:06 AM
Thanks for your reply PB !
Ok, I'm going to check again. What I don't understand is that the terminal 9 had the right measure before the short-circuit (I checked several time for each terminal until the 13th and the short circuit...). And then, after the short-circuit, the measure was 0. I guessed it had a link between both. There other incorrect measure (that is at 0 instead of 100) is B6.
So you can confirm me, a short circuit like that cannot damage parts (capacitors or resistors) ? I'm quite sure the short circuit occurred when I touched the 270 ohm 5w resistor and the terminal 15. But I may have seen it wrong and could have been with the terminal 14. Would your analyze would be the same in that case ?
Thanks again,
Julien
« Last Edit: October 24, 2015, 07:42:36 AM by ju29 »
Reply #3 on: October 24, 2015, 09:13:43 AM
Terminals 14 and 15 are in the high voltage power supply, terminal 9 and B6 are fairly well isolated from the power supply, so you need to look at the 3K resistor 100uF cap, and associated connections to determine why you have 0V at 9 and B6.  (This would've likely presented itself as an issue without the incident at T14/15)
Offline Ju29
Reply #4 on: October 24, 2015, 02:11:36 PM
Ok, quick update.
- I checked again all soldering I wasn't sure and desoldered them.
- checked all the wiring.
- desoldered/resoldered all wires, capacitors and transistor close to Terminal 9 and B6.
- checked the resistance again (all ok).
- checked the voltage and all the measures were almost perfect  even for terminal 9 (103) and B6 (102) but for few minutes only... Then Terminal 9 and B6 were at 0 and some others values slightly changed (increased).  :'(
As I wrote in my former message, when I tried the headphone, the sound worked perfectly for 2 or 3 minutes and then the sound of the left hear stopped.
I guessed there were a correlation between both so I wanted to try the headphone and checking settings in the same time (safely). I had no other choice to check this (cheap headphones that works perfectly with others devices).
So, after 5 minutes I plugged the Crack again. The sound was perfect and all the voltages measures were almost perfect (even Terminal 9 and B6 at 102 and 103). Then when the sound of the left hear stopped after 2 minutes the measures changed again (terminal 9 and B6 at 0 + other measures that slightly increased).
So.....  since the measures are fine for the 2 first minutes I guess my wiring + my solders are both ok..
It remains the hardware (bad components). Am I right ???
What do you think about it ?
If the hardware is the issue, any advices of where I could buy the same components (resistors//capacitors) ?
Thanks for you answers and you help. It will be fixed ! :)
« Last Edit: October 24, 2015, 02:14:54 PM by ju29 »
Reply #5 on: October 24, 2015, 05:45:41 PM
If you had a failed component, it would never work. An intermittent problem is a solder problem. You have a joint that ceases to make contact as it expands with the heat of running the amplifier. Fix your solder and fix your amp.
Offline Ju29
Reply #6 on: October 25, 2015, 04:04:27 AM
Thank Joshua Paul for your replies. Ok, I understand. I'll check again and will redo the solders.
I hope I'll find the issue soon ! :)
Reply #7 on: October 25, 2015, 07:01:56 AM
If you can post photos of your build, we might be able to visually identify the issue.
Offline Ju29
Reply #8 on: October 25, 2015, 07:46:14 AM
I desoldered in the meantime about 90% of what I built. During this I broke a leg (may be not the right term) of one of the HLMP 600 red led...  :-\ I'll have to order some spares.
« Last Edit: October 25, 2015, 08:55:45 AM by ju29 »
Offline Ju29
Reply #9 on: October 25, 2015, 07:48:19 AM
And again, thanks a lot for your answers and help btw. It's very appreciated !
Offline Ju29
Reply #10 on: October 27, 2015, 08:39:31 AM
Hello, after reading the instructions of the speedball upgrade (that I got in the same time of the Crack and that I plan to install.. one day :) I realized there were few leds in the package. So I took one and used it so as to rebuild my Crack (I ordered new leds from BH and there are on their way...)
So... I resoldered what I had undone (85/90%) and then check the measurements again.
Resistance check was ok but the exact same pb occurred this the voltage check :
every measurements are fine and after 2 minutes B6 and terminal 9 are at 0 (and the others measures that were fine increased slightly...
Following the instructions of Paul, here are a couple of pictures. I didn't take all solders in pictures but that's a start. Would you mind to have a look at it and tell me what you think ?
Now that I understand the pb is caused by bad solder where could possibly be the location of all the bad solders that could lead for sure to this issue ? I mean, can the pb come from any solders or is it no use to check some because they cannot have any effect on the issue ? (I hope I'm clear, english is not my first language so I try my best.. :) )
Thanks a lot,
Julien
« Last Edit: October 27, 2015, 08:45:45 AM by ju29 »
Offline Deluk
Reply #11 on: October 27, 2015, 01:27:48 PM
The black wires at 3 could do with some solder both sides of the tag strip but I don't think that is your problem area.
Offline Ju29
Reply #12 on: October 27, 2015, 04:36:11 PM
Ok, I desoldered at least twice each of them. Others solders, closed/linked to B6 and T9, more than that...
...and the same pb occurs.
Now, honestly I'm completely lost and really don't know what to do next. I feel sad and frustrated to have spent so many hours (days) for nothing. I just don't get it. I know it's an easy kit and there's no billion of places to check. With the $$ conversion, repair service is about 170$ + shipping (CAD) so it's not quite really an option for me right now.
I know I repeat myself with this question but does it have to be a bad soldering, for sure ?
Are there specifics checking I could do to try to locate the issue very precisely ?
(Thanks Deluk for your reply at my last message. I checked also this one but didn't solve the pb)
Offline Strikkflypilot
  • Shellac fiddler
Reply #13 on: October 27, 2015, 05:40:05 PM
Both sides of the tubes light up?
It happens after something grts hot enough, 2 mins. And all solder joints are rewetted/ reheated.
Is it unthinkable that there is a problem with the 6080 tube?
Maybe it should be swapped for another one?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Offline Ju29
Reply #14 on: October 27, 2015, 06:22:23 PM
Yes, the 6080 lights on both sides and much more than the other small one. I've just checked, both still glow when the music stop in my left hear.
I attach 2 pics of them.
« Last Edit: October 27, 2015, 06:24:39 PM by ju29 »
