Shorting Headphone Jack
ixe13 · 7210
Offline ixe13
on: October 27, 2015, 09:32:03 AM
Hi,
I own one of the earlier version of the S.E.X headphone amp. I'm looking for a shorting Headphone Jack for it.
Does anybody found a replacement one since the one that came on the later S.E.X. model is discontinued, does someone found a replacement one?
There is hundreds of different jacks available on line, but which one is adequate  ???
Thanx
Offline ixe13
Reply #2 on: October 27, 2015, 11:47:48 AM
Excellent , Thank you
Reply #3 on: October 27, 2015, 12:05:24 PM
http://www.mouser.ie/ProductDetail/Neutrik/NMJ6HF-S/?qs=%2fha2pyFadugRXvZJSjVeRsKWO27A0JP1H7ufvlHi3pg%3d
There is also an identical looking version from Neutrik with silver plated contacts instead of tin, but its twice the price.
Offline ixe13
Reply #4 on: October 27, 2015, 12:10:35 PM
But still pretty cheap.  I'll go with this one.
It's almost embarrasing ordering a dollar and a half item    :D
Offline i luvmusic 2
Reply #5 on: October 27, 2015, 12:29:34 PM
I hope you are not from CANADA or you will be slapped with a $20CAD shipping for a dollar and change order. ;D
Offline ixe13
Reply #6 on: October 27, 2015, 12:53:40 PM
Yep, I am from da north.
I know It's a bit ridiculous, but I really want to add this mod to my amp...
I'll try to find a dealer that carry those on this side of the border.
Ah well...
Reply #7 on: October 27, 2015, 12:56:52 PM
An eBay seller would be my first choice, always cheaper for shipping with small items like that.
Offline ixe13
Reply #8 on: October 27, 2015, 12:59:15 PM
Yep,
I'm on ebay right now!
Offline ixe13
Reply #9 on: October 27, 2015, 01:22:08 PM
Found this so far:
http://www.ebay.com/itm/1-pcs-Original-genuine-gold-plated-Swiss-Neutrik-6-35mm-headphone-jack-socket-/131387929023?hash=item1e9754b1bf:g:d00AAOSwLVZVkR0t
In China... Hell. Would like to support local bussiness though!
No hole for the wire. It's for a board. And is it genuine ?
« Last Edit: October 27, 2015, 01:24:31 PM by ixe13 »
Reply #10 on: October 27, 2015, 01:24:39 PM
And its the solder pin version for PCB mounting, you want the solder lug.  It can work, but its a bodge.
Reply #11 on: October 28, 2015, 08:20:05 AM
Do you have the jack that looks a bit more on the metal side than like black plastic?
Offline ixe13
Reply #12 on: October 29, 2015, 08:35:03 AM
It's the metal one.
Reply #13 on: October 29, 2015, 10:14:50 AM
That is the plastic one, which is the shorting jack.
Is your jack damaged and in need of replacement?
Offline ixe13
Reply #14 on: October 29, 2015, 01:40:44 PM
Hi Paul,
Well, actualy, it never worked, I assume that I had the one that doesn't short the speakers.
Is it possible that I got the wiring wrong ? It's definitivly stereo,  ;)
I followed the documentation supplied with the kit. I bought this kit in 2008 or so I believe.
Still working great with a pair of General Electric Tubes with around 4000 hours on them. (they test almost like new on my tube tester)
This amp sing along...
Thanx
