Speedball nylon standoff @ 9pin installation
Thebb · 1762
Offline Thebb
on: October 31, 2015, 02:20:30 PM
Just a quick question.
I can't seem to get the nylon standoff that is supposed to go on the top of the 9 pin socket to stay because there is not enough of the screw sticking out of the nut to screw the standoff on.  The instruction manual specifically says not to remove the nut, but I won't be able to screw it on otherwise.
Should I go out and get a longer screw at the hardware shop or is it ok to remove the nut?
Thanks for any feedback.
Offline richmi
Reply #1 on: October 31, 2015, 03:14:04 PM
The kit should have come with two 4-40x1/4" screws and two 4-40x3/8". The two 4-40x3/8" screws were to attach the two sockets and terminal strips together. The other two that are shorter go in the socket holes that have no terminal strips. Perhaps you used a longer one on the wrong side of one socket. If that is the case, you should not have to go out and buy extra screws, just swap them.
Richard
Richard Milette
Seduction C4S
Extended Foreplay III (converted to 6SN7 Nov. 2011)
Paramount 300Bs
Crack (6SN7) + Speedball + HD650
Offline Thebb
Reply #2 on: October 31, 2015, 07:25:11 PM
 ;D
That was it. Lol. Used it someplace else.
Thanks.
