Beepre noise
Jeroen · 2124
Offline Jeroen
on: November 01, 2015, 01:39:33 AM
Let me start by saying I love the Beepre. It's a great combo with the Eros and Paramounts!
Unfortunately I got a bit of a problem with noise. When the volume is turned down I get a little bit of noise, no problem at all. When I turn the volume up, the noise is increasing to a quite loud level. I can't figure out the problem. Since the tubes (and powersupply) are between volume and output the problem can't be there. I used the shielded wire from the kit, all earth connections are fine.
Does anyone has a suggestions what could be the problem? Help is very appreciated!
Best Regards,
Jeroen
Offline Jeroen
Reply #1 on: November 01, 2015, 02:51:49 AM
Hi Grainger,
Thank you for the tip. I'll make a pair of shorting plugs.
