Crack w/Speedball LED issue [resolved]
ZestyLemon · 1844
Offline ZestyLemon
on: November 01, 2015, 04:14:52 AM
I am having an issue with the 2 LEDs on the bottom left of the big PCB not lighting up, the voltage checks come out correct (+/- 15%) and sound comes out. I have checked all the connections on the PCB and reflowed them but that hasn't helped. Any advice?
« Last Edit: November 01, 2015, 10:41:12 AM by Caucasian Blackplate »
Reply #1 on: November 01, 2015, 06:12:54 AM
If the voltages at 7 and 9 are correct, the LED's on the big board should be lighting up.  What voltages do you have at 7 and 9?
Offline ZestyLemon
Reply #2 on: November 01, 2015, 09:00:49 AM
It turns out I had the cable from 9L going the the wrong side of the board, swapped it over to the O in the opposite corner and powered it on and the 2 LEDs powered on. The amp sounds so much better now. Thanks for your help!
