Just scored
proud indian · 28228
Offline proud indian
on: November 29, 2015, 11:31:31 PM
http://www.ebay.com/itm/Bottlehead-Foreplay-III-Tube-Preamp-alt-to-Antique-Sound-Labs-/371480507133?ul_noapp=true&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F0%252Fe11003.m43.l1465%252F7%253Feuid%253Df69faea7be59498baa5dc3846ab4a6b2%2526loc%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fulk%25252Fitm%25252F371480507133%2526exe%253D13457%2526ext%253D34396%2526sojTags%253Dexe%253Dexe%252Cext%253Dext%2526srcrot%253De11003.m43.l1465%2526rvr_id%253D0&nma=true&si=y36Xl3vGlrKqDRmJ9eGtD%252BqlkAc%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557#shpCntId
Ok. Got a foreplay lll for 165 bucks. I think it is a deal. As I have to get it to India and that would take a couple of weeks, any suggestions to make it sound better?  it should be 120v and I will have to change the transformer or use a step down, which would also isolate the power. Says it is not working, but I doubt that would br more than  an evenings work.
Shreekant :)
system 1. oppo, quickie,SEX 2.1 ( V cap), Decware DFR8 in ZOB cabs
System 2. Tascam cd200, Terra Dac,Zbox,Decware Zen amp(V cap) Lowther PM6A in Acousta horns.
Maple rack, Brass footers,Power conditioner, dedicated treated room, iso pads, plenty of tubes. All cables DIY.
Offline Natural Sound
Reply #1 on: November 30, 2015, 05:19:53 AM
Good one! I picked up a second FPIII about a month ago. It came with the extended kit parts which I haven't installed yet. Mine was $300 shipped.
I recommend that you leave the original transformer in place and use a step-down in front of the FPIII.
As for upgrades, I would get it running in stock form first. Then I'd replace the 2.2uf output caps with your favorite film cap that is in your budget. I have also played around a little with the cap that bypasses the 0D3 regulator tube. I wound up with a vintage VitaminQ cap in that location that sounds nice in my system.
There are other tweaks you can do in the power supply or replace resistors in the signal path with Dale RN55 resistors etc. But I found that those tweaks didn't make as much difference in sound quality as the output caps.
Good luck and keep us updated with your progress.
Reply #2 on: November 30, 2015, 06:24:43 AM
The best upgrade for that Foreplay would be the extended Foreplay III upgrade, which is long gone.
Beyond that, clean up any gnarly solder joints that you see, and you should be up and running nicely.
Reply #3 on: December 01, 2015, 03:00:19 AM
Thanks for the inputs. Grainger has suggested some ruskie caps for the bypass. As I dont have the manual as yet, what is the v for the 2.2uf and the bypass cap? For the film, what was your choice or rec. My daughter is down from San Jose by the end of the month , so I will get it shipped to her and she can get it here, so in the mean time I do have time to pick up a stuff I require.
Thanks.
Shreekant :)
Offline ike
Reply #4 on: December 04, 2015, 04:28:49 AM
I seconded Paul comment on the extended kit... I switched out the 12AU7 tubes to 6SN7 tube.  Not exactly an upgrade but rather a preference of sound...
Reply #5 on: December 11, 2015, 03:58:32 AM
Sorry for dropping out, but I live in chennai, India.  For those who may have been informed, it rained like crazy here. In 10 hrs we had more rain than the UK has in a year. Houses were flooded with water upto 20ft. Slowly the city limps back. Lucky for me it was not bad in my area as  the flood water stopped 200 yards away. No power for 3 days ( safety measure)
The foreplay has been delivered to my daughter who is travelling to india end dec.
So finally it looks like I  need a 2.2uf and a 0.1 uf cap. Will order them soon.
Shreekant
Reply #6 on: December 13, 2015, 06:58:37 AM
That sounds intense!
The 0.1uf cap can be anything between 0.01uF and 0.1uF, before the Extended Foreplay upgrade, I believe Doc B. was using a Russian teflon cap that was 0.056uF IIRC.
The 2.2uF cap value is flexible too, you can go considerably higher if you find something you like.
Reply #7 on: December 21, 2015, 05:44:24 AM
Thanks.  Will get back .......the amp reaches me on the 28th.
Shreekant
Reply #8 on: January 12, 2016, 03:04:29 AM
Checked the soldering etc and put in the tubes. The OD3 does not fire up, but the 12au7 gets warm. I tried 2 OD3 tubes so there has to be a problem. Any suggestions.
Shreekant
Reply #9 on: January 12, 2016, 10:38:52 AM
Check the voltages against those listed in the manual.
Reply #10 on: January 12, 2016, 07:30:03 PM
The Led on one channel does not glow. I have spare led's from the CS4 mods for my sex kit. Can the same Led be used here.
shreekant
Reply #11 on: January 12, 2016, 11:22:38 PM
Figured the led are the same ...... fp3 playing music now!!!!!
Shreekant
Reply #12 on: January 13, 2016, 02:16:21 AM
The OD3 does not glow, otherwise everything is fine.
Shreekant
Reply #13 on: January 13, 2016, 08:35:19 AM
You don't really know if it's working properly without testing the voltages.
If the 0D3 isn't glowing (it can be somewhat hard to see, but should be a dull pink), then your Foreplay is unlikely to be working properly.
Reply #14 on: January 13, 2016, 09:38:32 PM
Solved the problem. They guy who sold it to me connected R5 T22 instead of 21.  Now it reads 150 bang on !!!!!! The OD3 glows and so do I.
$165.....what a steal !!!!! Cant stop grinning.
Shreekant ;D ;D
