Kaiju with lower-efficiency speakers
dave-tx · 5853
Offline dave-tx
on: November 30, 2015, 03:30:03 AM
I'm pretty sure I know the answer from reading the specs, but thought I'd ask anyway...How practical is the Kaiju strapped for driving something like a 86-87dB Magneplanar speaker?
Reply #1 on: November 30, 2015, 07:37:31 AM
My usual estimate is the ability to generate 102dB peaks. At 16 watts (12dBW) that means speakers of 90dB efficiency.
This approximation comes from a compilation of Stereophile speaker reviews over a few years, in the late 90s; it is the minimum of their recommended power range. So I say this is good for "most audiophiles, most of the time."
For the median audiophile, you might get away with 6dB less efficiency, so 84dB minimum. This is mostly a combination of not needing exceptional loudness, and the fact that SETs overload really gracefully, so minor clipping is not objectionable. (High feedback and/or solid state amps have very hard clipping, so even minor amounts are quite objectionable.) Room size and absorptive treatments also play a role.
Sorry, that puts you in unclear territory - it's a judgement call.
Offline dave-tx
Reply #2 on: November 30, 2015, 10:42:45 AM
Thanks, Paul - You're right, it's a little unclear territory, but I'm inclined to give it a try.  I'm really itching to do a build and this is the excuse I'm looking for.  I can always work on more efficient speakers later, if needed.
I'm assuming the DC filament supply would likely be unnecessary with low-efficiency speakers, so I'll skip that for now.
Reply #3 on: November 30, 2015, 12:02:48 PM
We have many customers running 88dB efficient FE83 based speakers on their 3.5W Stereomour amplifiers without complaints (though in some cases the 0.3V signal available from a cell phone or DVD player necessitates a preamplifier).
The Magnepans are just a hair less efficient, but are also a mostly resistive load, so the extra power should put you in a similar territory.
We would be very surprised if the DC filament upgrade was audible in your setup.
Reply #4 on: December 01, 2015, 10:28:55 AM
FWIW, with my ~95db speakers. My SR-45 Amp 45's or 2A3 with 2.5V filaments. The hum is virtually inaudible, unless I put my ear to the speaker. When I switch to 300B, with 5V, I can hear a little hum at the listening position when no music is playing...John
Offline drewh1
Reply #5 on: March 20, 2016, 11:26:02 AM
FYI. I have a barely audible hum on mids, Tweeters r silent.  My speakers are 92db. I am going to install the DC filament supply because I  will be using Eml's.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Crack with Beyerdynamic T1
Offline dave-tx
Reply #6 on: July 17, 2016, 09:30:27 AM
For the record...The Kaiju as a monoblock sounds amazing with Magneplanar 2.7QR speakers.  If anyone has the same doubts that I did when I started this thread, you can lose them now.  Your milage may vary, but I'm nothing less than thrilled.
Offline quad
Reply #7 on: July 15, 2018, 07:31:46 AM
I know this post was ages ago... but what did you configure the kaiju output impedance selector for the magneplanars?
