voltage issue on terminal B1
tdonnellyem · 1660
Offline tdonnellyem
on: December 14, 2015, 06:06:31 AM
hey now,
so i went through and did my voltage check this morning.  all are within range except for terminal B1.  the target voltage is 90VDC.  i am getting a reading of 150VDC.  i plan to resolder the wire at both ends hoping its a bad solder joint. also in my haste when checking terminal A9 i touched A8 at the same time and shorted out the led that was glowing nicely up until that point.  i purchased the speedball kit at the same time and will rob peter to pay paul by taken a led out of that kit. i doubt that the led is affecting the voltage on B1 but figure i would mention it just in case.
thanks
tim
Reply #1 on: December 14, 2015, 06:33:55 AM
B1 wires to terminal 1, how's your voltage there?
Offline tdonnellyem
Reply #2 on: December 14, 2015, 09:10:06 AM
here is the listing of all my measurements
terminal           target voltage            measured voltage
  1                     75-90                          78
  2                      170                           172
  3                       0                              0
  4                       170                           171
  5                      75-90                         76
  6                         0                              0
  7                      100                            105
  8                        0                                0
  9                       100                            103
10                        0                               0
11                       0                                 0
12                       0                                 0
13                       170                             171
14                       0                                   0
15                       185                            193
20                        0                               0
21                        206                            213
A1                        90                            76
A2                        0                               0
A4                         0                              0
A5                        0                              0
A6                       90                              78
A7                        0                               0
A9                       0                                0
B1                       90                            150
B2                       170                          165
B3                       100                           149
B4                      90                               74
B5                       170                           164
B6                        100                          101
B7                       0                                0
B8                       0                                0
didn't notice it at first by my B3 voltage is high as well...thanks for the input on troubleshooting
Reply #3 on: December 14, 2015, 12:54:52 PM
B1 attaches to 1L with a piece of wire.
You have 150V at B1 and 75V at 1L.
We can conclude that B1 and 1L are in fact not connected by a piece of wire in your Crack.
