Input jack is scratchy
jimvibe · 2408
Offline jimvibe
on: December 17, 2015, 11:31:18 AM
Hello all,
I have been using crack for over 6 months now and everything was great, but recently the input connector suddenly started loosing the right channel for some reason. The solder joints going to the socket seem to be fine and the connector's leafs seem to be having good contact with the headphone jack. I will try to do a more thorough debugging soon, what else should I check?
Dima
Reply #1 on: December 17, 2015, 01:33:46 PM
recently the input connector suddenly started loosing the right channel for some reason. [...] the connector's leafs seem to be having good contact with the headphone jack.
Is it the headphone jack or the RCA jack that you suspect is flaky?  An intermittent channel is nearly always a flaky solder joint.
Offline jimvibe
Reply #2 on: December 17, 2015, 01:38:49 PM
It's the headphone jack. The channels goes away or comes back when I rock the headphone jack sideways just a tiny bit.
Offline jimvibe
Reply #3 on: December 18, 2015, 05:39:29 PM
Indeed, resoldered input jack wires and it seems to be fixed now. What a shame, considering that I have crimped every wire pretty hard-core and in the end had a working amp with few points unsoldered (was waiting for my speedball).
Thanks a lot!
