Fostex THX00 and the S.E.X
boulos · 2638
Offline boulos
on: December 21, 2015, 05:45:05 AM
I'm pairing the new Fostex THX00 with the SEX and it sounds great. Since these are 25ohm headphones, I'm using the L-Pad I built--I described that build in an earlier thread--allowing me more usable range on the volume control. The L-Pad also gets rid of the hum I hear with these headphones.  Note that with the HD600, I don't hear any hum (and of course, I don't need the L-Pad).
One question though. My SEX is set up with the 8ohm tap.  Would the 4ohm tap work better with these headphones assuming I still want to rotate between them and the HD600 every now and then?  I'm not using it anymore to drive speakers.
« Last Edit: December 21, 2015, 08:32:51 AM by boulos »
Reply #1 on: December 21, 2015, 07:08:16 AM
The 4 Ohm tap will have a lower noise floor than the 8 Ohm tap, but will still have enough power to drive both pairs of headphones.
Offline boulos
Reply #2 on: December 21, 2015, 08:32:17 AM
Thanks!  I'm debating whether to do that or to get the impedance switch kit for future compatibility.
