Bottlehead amp for BR-1 speaker?
yoshi800 · 2127
Offline yoshi800
on: December 21, 2015, 08:20:14 AM
I'm building a set of BR-1 speakers from a kit from Parts Express. Which Bottlehead amp (seductor, stereomour2, kaiju) would work best? I'm basically a noob but I'm willing to learn.
The stats on the BR-1's:
2-way bookshelf speakers
8 Ohm
100 watt power handling
83 dB sensitivity
Thanks in advance,
Fred
Logitech Media Server Hifiberry digi + & RPi 2 to Schiit bifrost multibit DAC, Smash Preamp w/ups, Kaiju Amp w/clarity mr caps driving DIY 8" Seas prestige speakers/DIY crossovers, Crosley c10 TT Ortofon 2m Blue cart. w/ Eros preamp; Crack w/Speedball Beyerdynamic cans.
Offline drewh1
Reply #1 on: December 21, 2015, 08:24:12 AM
My two cents, these speakers are not efficient enough for the low power SET tube amps. I run my Stereomour with 92 db speakers in a medium sized room and it is loud enough with a bit of headroom.  If you want to run tubes, look into a speaker kit that is a bit more efficient.
Ayre QB-9 USB DAC
Kaiju
Stereoumour
Crack with Beyerdynamic T1
Reply #2 on: December 21, 2015, 08:39:27 AM
Yeah, you would probably need something around 100W to get everything you might want out of an 85dB speaker in an average size room. The only amp of ours that would get satisfying dynamic levels from that speaker would be a pair of Kaijus strapped to mono for 16W. You could see 94dB peaks from that. It could work pretty well in a near field configuration.
Offline yoshi800
Reply #3 on: December 21, 2015, 09:56:13 AM
OK- After I finish these BR-1's I'll look at the kits at Madisound. Any suggestions on those? I prefer the DIY stuff.
Fred
Reply #4 on: December 22, 2015, 02:49:21 AM
For DIY speaker projects, especially single-driver designs that pair well with BH amps, the guys who run diyaudio have lots of plans, etc.
