crack resistance check problem [resolved]
damnub · 1784
Offline damnub
on: January 01, 2016, 07:20:03 AM
hello!
I finely finished my bottlehead crack build and it was a lot of fun. it was the first time actually soldering a project and im planning to do it again in the future:). but when i came to the resistance check everything but one was as it should have been. the terminal 6 is very off when it should have been 2,4k ohm. it gives between 2k and 30k but sometimes it sits steadily at 2,3k (where it shoud be) for  a few seconds. does any one know what causes this? is the capacitor broken? I can take a picture but that should take a while since my phone just broke.. but if its needed ill find something else. thanks for any suggestions
~damnub
« Last Edit: January 01, 2016, 07:42:05 AM by Caucasian Blackplate »
Reply #1 on: January 01, 2016, 07:21:47 AM
This sounds a lot like you may have a flaky solder joint making an intermittent connection.  You do not have a broken capacitor.
Offline damnub
Reply #2 on: January 01, 2016, 07:27:14 AM
I resoldered it and now it gives a steady 2,4k ohm thanks for the quick reply! now i can finely finish my amp:)
