Missing parts ? [resolved]
patm · 5193
Offline patm
on: January 10, 2016, 07:06:40 AM
Hi,
In troubleshooting an intermittent short causing one amp to fail. Reflowed most of the joints
I could get to, I started to disassemble the amp. I have had the soft start kit for a while so I decided to install it. While the 9 pin side is apart I will be able to access the remaining circut and reflow the joints.
On page 21 of the soft start manual, it asks me to install the 300k ohm resister ... . I did not receive any 300k ohm resisters in my kit and there is no 300 k ohm resister listed on page 11 in the kit parts list. Also I am missing a five lug terminal strip.
Pat McSween
« Last Edit: January 10, 2016, 09:34:20 AM by Caucasian Blackplate »
In the beginning there was nothing, then it blew up!
FP III, Paramount 300b (Takatsuki TA-300B), both with Mundorf S/O caps, Mikes iron, HFBG Eros,Oppo 103,Rega RP6 2m black ,Vaughn Triode JR II
Online Paul Birkeland
Reply #1 on: January 10, 2016, 07:19:17 AM
Hello Mr. McSween,
You can contact replacementparts(at)bottlehead(dot)com and we can get that taken care of for you.
As far as the manual goes, what is the date on the PDF that you have?  I just opened the manual, and the 300K resistors are on the parts list.
Offline patm
Reply #2 on: January 10, 2016, 08:40:11 AM
Hi Paul,
The date on my manual is 2010
These are the resistors listed on page 11 of my manual
2-330k
2-33k
2-249k
2-2.49k
4-147k
2-215
2-4.99k
6-220
2-90.9
2-10k pots
I will go to the address you mentioned.
Pat McSween
Reply #3 on: January 10, 2016, 09:08:27 AM
The manual was revised slightly in February of 2011, which explains the absence of the 300K resistors on the parts page.
Offline patm
Reply #4 on: January 10, 2016, 09:32:07 AM
Thanks Paul, I ordered the parts.
