Ungrounding Paramount PT-4 6.3V Center Tap
AudioDave · 5832
Offline AudioDave
on: January 21, 2016, 01:40:59 AM
I am toying with the idea of converting to DC filaments on my Paramount 5670 driver tubes.  I previously had purchased a couple of Ultra Low Noise regulated filament supply modules from DIY Hifi Supply and would like to use those,  however they utilize a full wave bridge for rectification so will need an ungrounded center tap on the PT-4 6.3V secondary.   My question is, which lug on the PT-4 is the 6.3V CT?   I guess my second question is, do you think this is a good idea or not worth the trouble?
Dave
Reply #1 on: January 21, 2016, 02:57:55 AM
The AC heating of the 5670 is, in our experience, not a significant source of noise.  Do your Paramounts hum audibly now?
Offline AudioDave
Reply #2 on: January 21, 2016, 03:36:05 AM
No,  not much hum at all!  Just in the mood to tweak and had the filament modules laying around.  Sounds like I should probably save them for another project!
Thanks for the feedback!
Dave
Reply #3 on: January 21, 2016, 03:49:08 AM
The key difference is between filament (right smack dab in the signal path) and heater (pretty well insulated from the signal path).  The directly heated output tubes in the Paramount benefit from DC heating (which they get), but the driver tubes do not.
Reply #4 on: January 21, 2016, 05:44:15 AM
The 6.3v winding CT is the center trace of the three parallel traces at the front of the PSU board, just left of center. It must be at AC ground, because it serves as a shield for the 300B/2A3 filament winding, preventing power line noise and high voltage rectifier noise from entering the filaments. In the stock design, it is grounded by the shield of the STP, at T17.
« Last Edit: January 21, 2016, 05:54:44 AM by Paul Joppa »
Offline AudioDave
Reply #5 on: January 21, 2016, 07:47:29 AM
Thanks Paul !
