Speedball Small Board Voltage Check Issue
onion_breath · 1837
Offline onion_breath
on: January 27, 2016, 11:41:20 AM
Currently in the process of installing a Speedball and am running into a few issues.
1. LED in position D1 on side B didn't illuminate.
2. Voltage reading on OB is low.
Here are my readings on the Small Board
Terminal     Voltage
OA              70.7V
IA               184.6V
B-A/B          0.001V
IB               184.6V
OB              54.46V
Reply #1 on: January 27, 2016, 12:02:56 PM
I would reheat the solder joints.  You're close enough that I would suspect that there's a partial impediment to current flow on the board itself.
Reply #2 on: January 27, 2016, 12:43:30 PM
Upon further inspection it seems as though I installed one of the PN2907A transistors backwards. Currently in the process of desoldering. Hopefully this fixes the issue.
*Update*
Removed the PN2907A and it broke - email has been sent for replacement part.
Would the transistor installation have any effect in the LED illuminating? I did go and reheat the solder joints on both the Small Board and on 5U and the LED didn't illuminate.
« Last Edit: January 27, 2016, 05:45:28 PM by onion_breath »
Reply #3 on: January 28, 2016, 06:39:03 AM
Yes, a backwards PN2907 will cause that kind of issue.  I wouldn't proceed with any other work until the replacement part has arrived.
