Bottlehead Kits
Stereomour II
Cap Upgrade - Stereomour II
amritdesai
17269
amritdesai
Full Member
Re: Cap Upgrade - Stereomour II
Reply #15 on:
February 18, 2016, 09:17:50 AM
I flipped the connections at the RCA inputs which fixed the issue.
Thank you Doc!
Things are sounding better than ever!
Zu Audio soul Mk II, w radian 475
Zu Mission Cables
Stereomour II, JJ 2a3 40
Clearaudio Concept Wood Ortofon Black
Eros Phono Pre
Schiit Bifrost DAC
Synergistic Research Black Fuses
Paul Birkeland
Global Moderator
Hero Member
Reply #16 on:
February 20, 2016, 06:16:54 AM
With the signal carrying wire, it looks like you have black wired to the center post of each RCA jack, and it looks like you've grounded those connections up at the pot. If this is true, this is backwards.
amritdesai
Full Member
Reply #17 on:
February 22, 2016, 12:03:41 PM
Yes, that was the issue - it was wired backwards.
Everything sounds great. Really happy so far. Thank you for your help.
Zu Mission Cables
Eros Phono Pre
Schiit Bifrost DAC
Bottlehead Kits
Stereomour II
