Eros Build Resistances Consistently Higher Than Called For
Sugar Man · 2368
Offline Sugar Man
    • The Last Honest Lawyer
Just finished my Eros and have the following resistances that are higher than called for:
2    85.4K   71K
4    74.9K   60K
9    46.6K   39K
10  46.6K   39K
12  74.9K   60K
14  85.4K   71K
A4, B4   .621K    *
A6, B6   74.9K   60K
C1  46.6K   39K
C2  75.1K   60K
C4  .621K    *
C6  46.6K   39K
C7  75K      60K
Because these measurements are more than 15% high, I thought I'd post before firing her up.
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
Reply #1 on: February 12, 2016, 06:22:52 AM
You're OK. When doing the resistance measurements you are mostly making sure there are no zeros where there should be a higher reading (and vice versa), that would indicate a miswire. Small variations like you are seeing usually happen because different DMMs react differently to capacitors in the circuit getting charged by the DMM's battery.
Offline Sugar Man
Reply #2 on: February 12, 2016, 06:29:52 AM
Thanks Doc.  Just like to be certain before venturing into the live voltage checks.  :o 8)
Mike "Stein" Ayotte
Current Gear:
Bluesound Node 2i
