Quickie: What's this, strange left channel slowly fades away: resolved
frank bare · 2964
Offline frank bare
Here you go. I'm listening and the left channel slowly fades away...Ok, what's up?
Not batteries, or tubes or cold solder joint...ready,? An easy fix. It was the On/off selector switch.
A bad switch. Hmmm. Found that if i apply slight pressure downward on the selector switch...it will cut out on the left channel...
Will replace, but thought for future Quickie builders, a helpful tip to check.
Bare
