Quick questions
Angst · 2637
Offline Angst
on: March 21, 2016, 12:52:17 PM
Considering buying
1.a. Can I convert the BeePre to 2-input, (3 or 4)-output?
1.b. Easily?  (I can't read schematics, but I can occasionally solder a joint without burning myself.)
2. Does the BeeQuiet stepped result in a lot of microphonics?
Thanks.
Online Paul Birkeland
Reply #1 on: March 26, 2016, 07:11:51 AM
It's really easy to add splitters to the outputs.  It's not terribly difficult to adjust the selector switch for 2 inputs, but I would just wire it stock because the instructions are provided.
There are some supplemental instructions to reduce the spring tension on the attenuator switches that make the switching action more gentle, which will reduce any microphony of the switching action through the 300B's.
