Attenuator problem?
Appleking · 1809
Offline Appleking
on: March 27, 2016, 02:16:50 PM
Hello everyone,
First time poster in this forum, first time builder pretty much first time everything. I'll keep it short and sweet. I finished assembling my crack amplifier and I plugged everything in and went to turn it on and when audio is played through it the volume is extremely quiet even at full volume. Note that when at minimum volume no sound plays out of the right channel and when the volume is turned up it slightly increases in the right channel to barely audible. Also every 30 seconds or so the volume will increase slightly maybe by 3 decibels or so then go back to quiet. I was just wondering if anyone here maybe has had experience with this type of issue? I've gone through the manual multiple times trying to correct the issue but I might just be missing something. Any potential leads would be extremely helpful. Thank you for your time and expertise.
-Alex
Reply #1 on: March 27, 2016, 02:51:45 PM
Did you do the resistance and voltage checks?
