Using Y Cables between DAC and AMPS
Mordicai · 2648
Offline Mordicai
on: May 03, 2016, 12:25:19 PM
I use a Stereomour and a Sex 2.1 fed by a Shiit Bifrost MB. Im getting tired of changing the RCA cables from one amp to the other. The DAC only has one OUT. I don't have preamp, so Thought I would make up two Y cables so I can run a second set of RCA cables. Bad idea? Any signal loss? Should a build a switching box instead ? Be happy for some feed back...Max
Offline Armaegis
Reply #1 on: May 03, 2016, 09:00:16 PM
There shouldn't be any signal loss unless there's something wonky with the input impedances on those amps. Otherwise it should be fine.
Offline STURMJ
Reply #2 on: May 27, 2016, 09:19:39 AM
My personal opinion is to make a switch box. There is always a possibility that there might be some impedance issues with the DAC "seeing" both amps even if one is not on.
