Appropriate cartridge
musiciseverything · 2477
Offline musiciseverything
on: May 31, 2016, 08:16:05 AM
Fresh off the addition of the PJCCS to my Quickie, I'm curious about this phono. I'm using a Graham Slee phono amp and it's good but the background noise is a little high. It's the Gold Era V. I'm using a MMF-7 table with its Goldring Eroica HO cartridge. The specs are below. What are your thoughts on matching this table and cart with the zeros?
Specifications
Frequency Response   20 Hz - 22 kHz 3 dB
Channel Balance   within 1 dB @ 1 kHz
Channel Separation    better than 25 dB @ 1 kHz
Sensitivity   2.5 mV 1 dB, 1 kHz @ 5 cm/sec
Static Compliance   30 mm/N
Dynamic Compliance @ 10 Hz
18 mm/N
Equivalent tip mass   0.6 mg
Vertical Tracking Angle   24°
Stylus Radius   Gyger II
Stylus Type   Non-Replaceable
Load Resistance   47 kΩ
Load Capacitance   100 - 500 pF
Internal Inductance   0.2 mH
Internal Resistance   77 Ω
Cartridge Mass   5.5 g
Cartridge Mass (inc. fixings)
6.6 g
Fixing Centre   0.5" (12.7 mm)
Playing Weight   1.5 - 2.0 g (1.7 g nom.)
Offline Hank Murrow
Reply #1 on: May 31, 2016, 02:11:36 PM
Dear musiciseverything;
I use the Eros with a VPI 19 table and a BPS EVO lll, which has an output of 2.5mv; and the combination is wonderful in every way. My Eros was built by Paul Birkeland of BH Customs and has CuTf V-Caps which are a worthwhile upgrade if you want more than stock.
Cheers, Hank
Reply #2 on: May 31, 2016, 03:36:23 PM
Very kind of you to respond.  That's good to know.  I will consider the kit now, if I can get enough money for my Graham Slee.  Thanks very much.
