Help with new build!! [resolved]
adeep42 · 1907
Offline adeep42
on: June 02, 2016, 04:08:06 PM
Just finished basic Crack. Resistance checks were perfect. Went to do voltage checks and Fuse blew. Can't find a wiring problem. Any thoughts, please. Also, must get new fuse. Parts list says 0.5A. Is it slow blow or fast blow? Can I use a different fuse. Thanks all. Was really hoping to listen tonight, but I guess I'll have to wait.
« Last Edit: June 05, 2016, 08:02:05 AM by Caucasian Blackplate »
Reply #1 on: June 03, 2016, 03:28:16 AM
1A fast or slow. Check orientation of all caps and UF4007s.
Offline adeep42
Reply #2 on: June 03, 2016, 09:55:55 AM
Thank you so much Josh. I blew the orientation on the last UF4007. Now have a beautifully functioning CRACK. Sounds great, looks great. Will revel in it till I get the urge to install the Speedball I purchased along with it.
Will post some pictures in the gallery a little later.
Offline adeep42
Reply #3 on: June 22, 2016, 10:58:03 AM
Triumph. Speedball installed. Wow!!!!!!!!!!!!!!!!!!!!
Thank you Doc and all the Bottlehead crew. I couldn't be happier. Am now considering Eros.
Offline Rocketman248
Reply #4 on: June 22, 2016, 11:23:03 PM
Go for it!  The Eros took my vinyl setup to a completely new level.
Nick DeBrita
Yokosuka, Japan
