Hi everyone,
I've just put together my Reduction and performed the tests. The resistance tests all passed, but the voltages failed on 2:
Terminal 10 is 74.3V when it should be 0
Terminal 60 starts at ~120V and slowly drops. I let it get to 100V in about 20 seconds. Should be 165V
I will also note that the LED connected to B4 turned off when measuring terminal 30, but came back on after turning off and back on the amp. It also turned off when measuring 51 but came back on a few seconds later.
I've done a visual inspection of the circuit and gone back through the instructions to see what I missed but I can't spot it. A bad solder somewhere maybe? I'm finding it hard to link the 2 problems, unless they're not related.
Any help would be much appreciated
