Another Compatibility Question
adeep42 · 3988
Offline adeep42
on: June 08, 2016, 07:45:34 AM
Just finished my Crack. No speedball yet, but it's just super. Thinking about an Eros as a phono-pre upgrade. Cartridge would be Ortofon Cadenza Bronze with Bob's Devices VPI SUT. Any thoughts out there? Thanks in advance.
Alan
Offline fullheadofnothing
Reply #1 on: June 08, 2016, 08:11:47 AM
What's the ratio of the SUT?
Offline adeep42
Reply #2 on: June 08, 2016, 08:33:49 AM
Ratio is switchable, 1:10/1:20. Btw, gain of my current pre is 43dB, 7dB less than the Eros. I use the higher ratio.
« Last Edit: June 08, 2016, 08:43:16 AM by adeep42 »
Reply #3 on: June 08, 2016, 08:57:43 AM
1:20 is coming into the Eros pretty hot at 8mV. It should be OK, but you may experience some clipping. The 1:10 may be a better bet, but you're going to have to try it both ways.
Offline adeep42
Reply #4 on: June 08, 2016, 10:38:11 AM
Thanks Josh.Appreciate your thoughts.
Offline adeep42
Reply #5 on: June 08, 2016, 01:20:02 PM
Josh or maybe Paul,
I'm somewhat concerned about the higher gain as well as interaction with my SUT. Do you think I would be better off with the Reduction plus Integration Upgrade?
Thanks again,
Alan
Reply #6 on: June 08, 2016, 02:14:07 PM
Sorry if this was unclear before. Your pairing with an Eros should be fine. It does have a rather high (though not insanely high) output, which might be an issue. You will need to try it to find out. Should you find it to be a problem, you have the option of using your lower ratio for a 4mV input, which is just about perfect.
FWIW IIRC, I believe the Eros circuit is more tolerant of overpowering the input. It will also sound better.
Reply #7 on: June 14, 2016, 07:31:56 AM
You'll be right on the money with the 1:10 configuration.
Offline adeep42
Reply #8 on: June 14, 2016, 11:46:46 AM
Thank you Paul. After I get to the Speedball for my newly beloved Crack, That might be the next challenge to these old hands and eyes.
Btw, what are the dimensions(width and depth) of the Eros including case.
Thanks again,
Alan
« Last Edit: June 14, 2016, 11:50:24 AM by adeep42 »
Offline Sugar Man
    • The Last Honest Lawyer
Reply #9 on: June 14, 2016, 12:38:12 PM
11.25" x 9.25" are the outside diameter measurements.
« Last Edit: June 14, 2016, 12:42:40 PM by Sugar Man »
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
Offline adeep42
Reply #10 on: June 17, 2016, 06:32:56 AM
Thanks Mike
