Low volume right channel [resolved]
Karl5150 · 6263
on: June 10, 2016, 12:18:55 PM
As I said in my gallery post I have a very noticeable channel imbalance. Side to side tube swapping doesn't help. When I swap in and out cables on the Quickie the right channel (being fed by the Quickie's left) is still low.
I went back through the resistance and voltage checks. All the resistances run +10% consistently.
All 0 ohm, OL & 0 V are as they should be.
I noticed the first few voltages started +10% but slowly dropped as everything warmed up.
After it was stable all the 95-100 V terminals read +1% to +6%.
All the 212-425 V terminals read -2% to -4%.
Terminal 12 (30-55V) reads 48 V but terminals 18 & 28 read 23 V.
So it seems the left channel is high, not the right channel being low.
Any insight from the crew would be appreciated.
« Last Edit: June 14, 2016, 07:35:49 AM by Caucasian Blackplate »
Reply #1 on: June 10, 2016, 12:47:58 PM
Maybe double check the output transformer wiring?
Reply #2 on: June 11, 2016, 06:58:21 AM
 Oooops, and that's why he's the Doc.
Thank you for the diagnosis, the kits and the music!
