revision in crack plans
mike langer · 1911
Offline mike langer
on: June 18, 2016, 08:18:25 PM
Hi, on page19 of my new crack manual,there is a revision dated 5/6/10 that changes a cut black wire from 2" to 3" and has you solder one end to term 4 of power trans.and other to term 14u instead of term 22l. it states that may yield quieter operation. do you recommend this revision?
Also- maybe dumb but are resisters directional?
thanks you guys( that includes girls)
Reply #1 on: June 19, 2016, 04:17:23 AM
1) The difference is theoretical and you would be hard pressed to hear a difference. It really doesn't matter as long as the wire is attached to ground.
2) Resistors are not directional.
Offline mike langer
Reply #2 on: June 20, 2016, 04:44:13 PM
nice to make your acquaintence. this is my first build and i'm loving it.
tip: i bought cheap aluminum hair clips in the supermarket- they make easily customizable heat sinks i have melted no plastic
have a greaqt night y'all
