Crack Manual Question
scotth · 1445
Offline scotth
on: July 17, 2016, 10:04:44 AM
I am currently building the Crack and was a little confused about something. Under "Heater Wiring" it says to attach but not solder B8L and B7L but never goes back and tells you to solder them that I can see. The next step is soldering B8U and B7U, am I supposed to solder B8L and B7L at the same time? Am I missing something? Thanks.
Offline scotth
Reply #1 on: July 18, 2016, 08:05:54 AM
I got to the end and didn't see any other directions for those terminals, so I just soldered them then. Everything measured right and worked the first time without any issues. Must be beginner's luck.
Reply #2 on: July 24, 2016, 05:36:16 AM
Yes, you can just solder B7 and B8 when the second set of wires is attached.
