Weird noise with 2006 SEX [resolved]
pendergast · 1999
Offline pendergast
on: July 19, 2016, 11:15:31 AM
Hi,
I am the (very-very) happy and proud owner of a SEX purchased as a kit here in 2006.
I am sad tough because when I turn the volume up there is a sound like an "electric scratch" coming through the right side, both using headphones or the speakers. The noise does not change in intensity as I turn the knob.
A visual inspection shows no disconnect or bad soldering (though I have not touched it since the iron upgrade from 2007 or 2008).
Now, would I be right to suspect that the issues is with the dual 100 k potentiometer? Or could there be another issue?
Thank you in advance for your help!
« Last Edit: July 24, 2016, 05:57:43 AM by Caucasian Blackplate »
Offline johnsonad
Reply #1 on: July 19, 2016, 02:34:33 PM
You may want to try swapping the tubes and see if the sound changes to the other channel.
Offline pendergast
Reply #2 on: July 19, 2016, 03:05:32 PM
No change. Actually, it seems that the noise isn emitted through both channels, and only when I turn the knob. I guess the pot is dead.
Offline johnsonad
Reply #3 on: July 19, 2016, 03:16:35 PM
With the amp off you may want to try rapidly turning the knob in question back and forth to both ends. Somethings those carbon pots need a little cleaning to quiet down.
Offline pendergast
Reply #4 on: July 19, 2016, 03:32:08 PM
Where is the Nobel prize for simple solutions?  You deserve it!
The Joy of SEX is back!
Thank you!
Offline johnsonad
Reply #5 on: July 19, 2016, 03:59:21 PM
It's an old trick with carbon pots. Do it every few months to keep the contacts fresh. Enjoy!
