Pre-amp needed?!
eddhartwellmusic · 4077
Offline eddhartwellmusic
on: September 08, 2016, 11:32:11 PM
Hi, please forgive my ignorance, but I currently have a Rega RP6 turntable, with the Exact MM cartridge, Rega Fono stage and Bottlehead Mainline headphone amp.
I was looking at getting the Bottlehead Reduction to replace the Rega, but I have a couple of questions -
1. I'm pretty sure it is, but this phono stage is designed for Moving Magnet cartridges right?
2. Will I also need a pre-amp? (hence the subject title  ;) )
If any advice could be given before the sale ends on Sunday, that'd be great!
Offline Chris65
Reply #1 on: September 08, 2016, 11:35:21 PM
Yes, the Reduction is a MM phono stage. This can feed your Mainline directly, no need for a pre-amp.
Reply #2 on: September 09, 2016, 04:48:56 AM
Reduction is intended for use with MM cartridges with at least 5mV nominal output. The Exact is well above that and should be a great match.
