Garrett Optim FGS with Reduction + Integration
audiomaniac · 5092
Offline audiomaniac
  • No hill too steep, no ditch too deep!
on: September 10, 2016, 06:47:02 PM
After building a Crack, I'm planning on upgrading my phono playback system with a Reduction + Integration build. The thing is that my cartridge is 4Mv output. Will this be too low or boderline for a good result with the Reduction? I'll probably be adding the Integration upgrade right away during my build. I figure why wait? I'm hoping that will put me in the ballpark with gain. Thanks.
John
Crack
Offline Chris65
Reply #1 on: September 10, 2016, 10:55:58 PM
I don't expect you'd have any issues, I use my Reduction + Integration quite successfully with (amongst others) a Nagaoka MP-30 which has a listed output of 3mv. ;)
Reply #2 on: September 11, 2016, 05:57:14 AM
Build the Reduction stock first. If something goes wrong, it will be easier to diagnose the problem on the simpler stock circuit.
Offline audiomaniac
Reply #3 on: September 11, 2016, 07:49:31 AM
Ok thanks very much for the replys. I appreciate it. I'll build it stock first.
John
Crack
Reply #4 on: September 11, 2016, 10:10:22 AM
You're about on the money for the gear that you have.
The gain issue occurs mostly with Sex/Stereomour users who have inefficient loudspeakers.
Offline audiomaniac
Reply #5 on: September 11, 2016, 11:13:42 AM
OK, thanks much. I'm excited to get it and start building!
John
Crack
