Eros Build - Resistor question
amritdesai · 2452
Offline amritdesai
on: September 22, 2016, 06:55:00 AM
I seem to be missing two 470k ohm resistors in my kit (4703F). I am on page 67 of the manual and I have two remaining resistors left - Green, purple, black, orange, brown that are not measuring 470k ohm (see below). Also, I do not see these on the list of parts.
I just wanted to verify these are the incorrect parts before I bug Eileen? Can I go with something with a different value?
Thank you!
Zu Audio soul Mk II, w radian 475
Zu Mission Cables
Stereomour II, JJ 2a3 40
Clearaudio Concept Wood Ortofon Black
Eros Phono Pre
Schiit Bifrost DAC
Synergistic Research Black Fuses
Offline fullheadofnothing
Reply #1 on: September 22, 2016, 07:01:28 AM
0.474MΩ = 474KΩ
AND
470 x 1% = 4.70
SO
470±1% = 465.3 - 474.7
THEREFORE a resistor that measures 0.474MΩ is a 470KΩ with 1% accuracy.
Offline amritdesai
Reply #2 on: September 22, 2016, 07:12:37 AM
Awesome. That's why I asked!
Thank you Josh!
Zu Mission Cables
Eros Phono Pre
Schiit Bifrost DAC
Reply #3 on: September 22, 2016, 07:55:09 AM
The first stripe is yellow, not green. Yellow is 4.
Offline Rocketman248
Reply #4 on: September 22, 2016, 01:50:27 PM
lol I went through the same thing during my Eros build.  I had to go through the parts list about 3 times before I got everything sorted.  Then, I still messed it up by putting a 47k resistor in a 470k spot.  Too many 47s  :o
Nick DeBrita
Yokosuka, Japan
