PS film cap
johnsonad · 3508
Offline johnsonad
on: September 24, 2016, 12:36:21 PM
Team BH,
Given the Eros is a shunt regulated design, is there any benefit swapping the 100uF 450v lytic in the PS for a 100uF 500v film cap?
Aaron
Offline BNAL
Reply #1 on: September 24, 2016, 02:46:33 PM
Aaron,
I would think that any benefit using film cap would be greatly diminished with the additional regulation of the Eros. Not to say you would not hear it.
That's just my 2 cents.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Reply #2 on: September 24, 2016, 05:49:54 PM
It will give you warm fuzzies inside, but a large benefit of the hybrid regulator is relative immunity from power supply nasties.
Offline JamieMcC
Reply #3 on: September 24, 2016, 09:53:35 PM
I am suspecting this is also true on switching out the 270W 5W wirewound resistor resistor for a choke?
« Last Edit: September 24, 2016, 10:08:00 PM by JamieMcC »
Reply #4 on: September 25, 2016, 07:10:14 AM
Yes, the C4S load that feeds the whole circuit appears as roughly 10M-15M of impedance to 60Hz ripple.  An equivalent choke would be 30,000-40,000 Henrys.
Offline johnsonad
Reply #5 on: September 25, 2016, 11:35:14 AM
PB I see what you're saying but is there any advantage to lowering the ripple by using a choke in place of the 270 Ohm resistor in the PS before the shunt reg?  I'm assuming it's one of those try it, and listen to it mods.
Reply #6 on: September 25, 2016, 11:45:32 AM
You can try it and measure the ripple on the regulated B+ before and after.
Offline johnsonad
Reply #7 on: September 26, 2016, 04:13:58 AM
I'm pretty sure my scope is not sensitive enough for that but I'll try it at some point. Thanks.
