Eros build progress pics
JamieMcC · 10260
Offline JamieMcC
on: September 29, 2016, 08:42:03 AM
Hey guys I’m really enjoying the Eros build so far and as soon as my little ones are safely out of the way upstairs enjoying their bed time story with mum I get the chance to reclaim our dining room table get the soldering iron out and make a little bit more progress.
All has gone reasonably well so far and tonight fingers crossed the goal is to successfully completed the transformer tests and check it off the list.
Here are a few progress pics of how its coming together for you
You might notice the 5W 270 Ohm cement resistor which is sitting close to the pcb board the one from the kit was missing and I had one which I had pulled from a Crack when changing it for a choke there wasn’t much left of the leads so it went in but I ended up swapping out for a metal shielded one I had a couple of in the parts box so its stands off of the pcb a bit more. As I have a couple of chokes as well I suspect I will try one of those out at some point in the future.
« Last Edit: September 29, 2016, 08:49:13 AM by JamieMcC »
Reply #1 on: September 29, 2016, 08:51:15 AM
Lulz...
Offline johnsonad
Reply #2 on: September 29, 2016, 09:11:23 AM
Looking good so far! Have fun and take your time. I just finished mine and will be posting on it soon.
Offline JamieMcC
Reply #3 on: September 29, 2016, 09:20:39 AM
Lulz...
LOL Doh where is the face palm icon no wonder I couldn't see a big white cement resistor I should have been looking for a big green one instead  :-[
Edit At least that was a easy fix
« Last Edit: September 29, 2016, 09:35:28 AM by JamieMcC »
Offline ALL212
Reply #4 on: September 29, 2016, 10:24:42 AM
I envy the carbon!!!
Nice...very nice...   8)
Aaron Luebke
Offline BNAL
Reply #5 on: September 29, 2016, 10:47:13 AM
It is looking good. I like what you have done with the carbon wrap.
I have the power supply installed on mine and moving onto the shunt reg. Can't wait hear how it sounds.
Brad Nalitt
Iron Upgraded S.E.X. Amp 2.0
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline adeep42
Reply #6 on: September 29, 2016, 11:05:31 AM
+1 re: the Carbon Wrap. How do you do that?
Offline JamieMcC
Reply #7 on: September 29, 2016, 10:01:11 PM
I glue a thin real carbon fibre veneer to the Eros top plate (gorilla glue) then use a dremel with a drill bit fitted to cut out the holes by following the edges of the cut outs and using the spiral part of the drill bit to do the cutting from the non carbon side.
Offline adeep42
Reply #8 on: September 30, 2016, 04:27:59 AM
Very cool. Sort of committed to the red spray job, but would love to try that on the next project.
Alan
Offline JamieMcC
Reply #9 on: September 30, 2016, 05:16:57 AM
Snap thats just about where I am up to now
Offline BNAL
Reply #10 on: September 30, 2016, 05:53:05 AM
I still need to wire the heater, so you are ahead.
I did not work on the circuit last night, but plan to get a lot done this weekend if I can find the time.
I built the CCS boards with the servo, but I'm thinking of removing it. As I get closer to installing them I will decide.
I also, ordered more 6BR7s, so that I have a good stash of them.
Brad Nalitt
Foreplay III
Quickie w/PJCCS
Eros Phono
Offline JamieMcC
Reply #11 on: October 03, 2016, 12:26:46 PM
I've been up and running for a few hours now and the Eros is sounding very nice
The end was nearer than I had thought, after spending about ten minutes chasing down a couple of odd readings on the resistance checks I moved on to the voltage checks and all passed with flying colours.
I still have a few more mods in mind but going to enjoy the fruits of my labour for a while and celebrate with a wee dram.
Cheers Bottleheads
« Last Edit: October 04, 2016, 01:22:26 AM by JamieMcC »
Offline johnsonad
Reply #12 on: October 03, 2016, 01:14:15 PM
Congrats on finishing the build!
Offline Rocketman248
Reply #13 on: October 03, 2016, 01:16:20 PM
Looks great!  The Eros is a great preamp.  Since I built mine, I've found myself listening to vinyl much more than any other source.
Nick DeBrita
Yokosuka, Japan
Offline ALL212
Reply #14 on: October 03, 2016, 01:37:01 PM
COOL!!!   8)
I'm with Rocketman248.  I've not pulled so much vinyl as I have in the last week as I have over the last year.  And now shopping for more...
'splain the guts...more pictures!
Aaron Luebke
