Advice needed on Crack issue
barontan2418 · 1888
Offline barontan2418
on: October 04, 2016, 03:55:25 AM
Hi. After paying out £140 to repair my Crack + Speedball because it losses the right channel after about 15 mins of play, it's doing the same again. First time the enginer changed a couple of components on the speedball cct board. I was wondering if this has been an issue for anyone else and if so what the possible causes might be? Any help would be appreciated otherwise sadly it will be the end of the line for what was a great amp.
Reply #1 on: October 04, 2016, 04:47:07 AM
1) you have a bad solder joint.
2) you have a TERRIBLE technician.
Reply #2 on: October 04, 2016, 05:26:27 AM
I do suggest to our customers that, if you are going to pay that much you really ought to send it to us for repair. There is no one around who has more experience with these kits than we do.
It sounds like a bad connection or a thermal issue, or both. It's difficult to narrow it down much more than that without voltages. If you would like some assistance the best thing to do is start here:
http://bottlehead.com/smf/index.php?topic=1667.0
Offline ALL212
Reply #3 on: October 04, 2016, 11:45:08 AM
Pictures!!!
And - yank the speedball if the only option is not using it.  Still sounds great without it.  You'll need to source a few resistors but they should be readily available.
Aaron Luebke
Reply #4 on: October 11, 2017, 04:10:52 AM
Just wanted to apologise for my ignorance in not posting a reply after members had taken the time to assist. its not like me but I put my Bottlehead into hibernation and forgot to get back to the forum. Sorry.
