6n6p tubes
pro_crip · 8608
Offline pro_crip
on: August 07, 2010, 02:34:01 PM
I've got some of the aforementioned tubes in my stash, from a project that doesn't look like is gonna happen, and I was wondering, aside from any pin-out changes, if they can be used in place of 12au7's. I know enough to check that they're both the same type of tube (dual-triode) but I don't know what else to compare. Thanks a bunch.
Rich
Richard J Feldman
Professional Gimp,connoisseur of Bourbon and Vinyl, metalhead
Crack, Extended FPIII, Eros, Paramount 300B's (in the midst of construction)
Tune down, smoke up
Reply #1 on: August 08, 2010, 12:51:41 PM
To determine whether two tubes are electrically compatible, you must check the operating parameters, the maximum conditions, and the heater requirements.
Heater requirements are just the voltage and current needed. Performance parameters for triodes are gain (mu), transconductance (gm) and plate resistance (rp, sometimes ri). Any two of these will determine the third.
Operating limitations are maximum plate voltage, maximum cathode current, and possibly other items which may be mentioned in the data sheet. Here you have some leeway; the replacement must tolerate the actual circuit but need not match the original's maximum conditions if they are higher than the circuit demands.
The 6H6P has an rp of 1.9k, less than a quarter of the 12AU7, so even though the mu at 20 is close enough the 12AU7's value (17) the tubes are not compatible.
Offline pro_crip
Reply #2 on: August 10, 2010, 05:12:07 AM
Thanks, Paul for the info.
Rich
Richard J Feldman
Tune down, smoke up
Offline Dyna Saur
  • Yippie-Ki-Yay....
Reply #3 on: August 10, 2010, 04:40:41 PM
6N6P data sheet (PDF format) is here:  http://frank.pocnet.net/sheets/113/6/6N6P.pdf
ed brown
