Can I use the leftover wires from Crack for Speedball upgrade?
cddc · 3200
Offline cddc
Just realized that I could use the leftover Crack wires to connect the Speedball boards.
The Crack wires have a larger diameter than the ones within the speedball package. I think they will conduct signal/current better, am I right?
So, can I use the leftover wires from Crack for Speedball upgrade?
Really appreciate it if someone could shed some light on it.
Offline Tom-s
Reply #1 on: December 06, 2016, 10:27:43 PM
Yes these are tight but do fit the Speedball boards, so you could use them.
For ease of installation i would recommend using the wiring supplied with Speedball.
This also helps when you would like to replace the original Speedball boards for upgrades in the future.
Offline JamieMcC
Reply #2 on: December 07, 2016, 01:19:26 AM
I think the Speedball hook up wiring is Teflon coated and the thicker 20awg that comes with the Crack is not and the jacket can melt back a bit when soldering if not careful.
Reply #3 on: December 07, 2016, 03:02:49 AM
Correct its PTFE vs regular PVC and has a much higher melting point.  I think its also silver plated vs tin of the regular wire.  Its really nice stuff..
« Last Edit: December 07, 2016, 03:04:30 AM by mcandmar »
Offline cddc
Reply #4 on: December 07, 2016, 08:17:21 AM
Great, thank you so much for your advice Tom-s!
Offline cddc
Reply #5 on: December 07, 2016, 08:24:43 AM
Sweet, thanks Jamie. It's good to know.
Crack wires are of high quality. Among the numerous Crack wires I only melted back one or two of them a little bit, no big issues.
I am still thinking the quality of conductivity is the most important thing.
Offline cddc
Reply #6 on: December 07, 2016, 08:30:04 AM
Thank you very much for the details about the wires in Crack vs SB.
Melting is not a big concern to me as stated above.
The silver plating (vs tin) definitely helps, but not that much IMHO (unless the SB wires are pure silver).
I still think the thicker Crack wires will have better conductivity.
Reply #7 on: December 07, 2016, 09:19:23 AM
The longest wire in a Speedball 1.1 is 2 3/4".  That length of 22AWG wire has a resistance of 0.004Ω. 20AWG wire has a resistance of 0.002Ω
Offline cddc
Reply #8 on: December 07, 2016, 09:37:43 AM
So accurate measures...you are scientist...lol
Thank you very much!
Reply #9 on: December 08, 2016, 10:32:34 AM
40 AWG wire would be sufficient for installing the Speedball.  We provide the Teflon coated wire for the Speedball because the jacket won't melt and the thin jacket makes wire routing easier.
