When should I turn my amp off?
pemberley · 1712
Offline pemberley
on: December 07, 2016, 08:08:08 AM
Should I turn my amp off whenever I'm not using it, or only when I'll be away for an extended period of time?
Which puts more wear on the tubes, running idle for several hours or getting power cycled?
In case it matters, I've got a Crack with Speedball.
MOTU 16A -> Crack with Speedball -> HD600
Offline Zimmer64
    • Blog
Reply #1 on: December 07, 2016, 08:49:37 AM
I switch my amps off if I don't plan listening in tne next hour and definitely when I leave the house.
Michael
Offline ToolGuyFred
Reply #2 on: January 11, 2017, 04:47:05 AM
I tend to leave the preamp powered up if I'm going to use it in the next few hours. The headphone amp and power amps I'd agree with an hour. From a safety standpoint, treat all tubes with the same caution as an open flame (candle, kerosene lamp etc.) so if I'm out of my listening room then all off.
John
Amateur Audiophile and Backstreet Boffin.
Original Foreplay with C4S + Sweet Whispers
ParaSEX amps with MQ nickel-cored outputs
Factory-built Lowther Acousta 115s with silver-coiled DX3s, wired in DNM solid-core
KEF active sub (help for the last couple of octaves).
Bottlehead DAC on batteries.
